Factory gauges
I connected factory temp gauge. Mechanical gauge shows 195 and I know it's right because cooling fans come on at 190. Does factory temp gauge read right? Also my oil pressure gauge reads over half at idle, at 3000 rpm past h and at 6000 it's off a scale. Bad oil pressure gauge?
Re: Factory gauges
Your temp gauge I don't know but my oil presser gauge is like that to but it doesn't go past high like that it will only go to high.
71 c10 with a 305. new dd wohoo 1956 chevy bel air hard top with a 327. 1998 honda passport V6 old dd. |
The Red Menace
Re: Factory gauges
My temp gauge reads a little less than that, but it went higher the one time my coolant was low. My oil pressure gauge does the same as yours. I don't have a tach, but it goes up a lot at higher speeds.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
Re: Factory gauges
Your guages are as close to right as factory guages get. My bb idles at the 3/4 mark and goes past "h" when running down road. 327 in 68 idles just below half mark in park at first hash mark in gear and goes to about middle or just above driving down road. Oil pressure is in 15 lb increments so you are running approx. 45# of pressure. temp guage will most likely stay there until you change out thermostat. 180 will put it at first mark if that is what you are after. Long and short your guages are good.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
