Old 07-11-2010, 08:40 PM   #1
cstm68
cstm68's Avatar
air ride install. now truck wont turn over
heres my problem, my truck was starting and running great today then i hooked up my compressors and wired all my valves for my air ride, now everything works but the truck wont turn over no clicks or anythig.
with my air ride wired in could i be drawing too much power to turn over the engine? should i run 2 batterys? any help would be great! thanx
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 07-11-2010, 09:02 PM   #2
dirtyd_nd
Re: air ride install. now truck wont turn over
I would start by disconnecting your compressors and going from there. If it starts, check all your wiring. Make sure you didn't miss wire something. If it doesn't start, leave it disconnected and check fuses, wires, and the battery.
Dale
dirtyd_nd is offline   Reply With Quote
Old 07-11-2010, 09:04 PM   #3
7T2
Active Member
7T2's Avatar
Did this happen right away or did it sit overnight? If it sat overnight and you have leaks in the system your compressor will keep turning on to fill the tank until it eventually kills the battery.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 07-11-2010, 09:07 PM   #4
cstm68
cstm68's Avatar
no it hasent sat over night, its beeen just a few hours
Old 07-11-2010, 09:07 PM   #5
hotrodhomi
hotrodhomi's Avatar
how did you wire your compressors? You should be using a relay, if not you probably blew a fuse or fusable link. Its impossible to say without knowing what and where you added wires. Do you have a multimeter? If not, that's the first purchase I would make.
Are you sure you hooked everything back up?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 07-11-2010, 11:10 PM   #6
71 super
71 super's Avatar
Did you disconnect battery when you wired everything up? If you did check your grounds if it is not making a good connection, the accessories will work (low draw) but starter will not have enough to turn over- too much resistence. I would start there. The fusable link will prevent everything from working so if you are powering the little things it is out of the equation. Also check the state of your battery, if you played with the compressors you may have drained it past a working voltage for the starter. Ground would be my first choice however...
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-11-2010, 11:24 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Great minds think alike...posted this in his build thread
Originally Posted by VA72C10 View Post
is it clicking at all? Maybe just not enough juice to turn it over since you were playing with the compressors? THey take a lot of juice....or did you mess with any ground wires and maybe leave one off? Also check the connection at the battery...mine would let the lights work but not turn over when it was loose at the terminal....tightened it down and it started right up...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-12-2010, 01:13 AM   #8
cstm68
cstm68's Avatar
i have a relay for bolth compressors, i am charging the battery over night to see if that will help, tomarow i will check all my grounds,
i am using a painless wiring kit too if that helps.
Old 07-12-2010, 05:29 AM   #9
RossRinSD
RossRinSD's Avatar
I had an S10 on bags. The compressors had a pressure switch and was wired to constant +12V. I had to change it to a +12V IGN. It didn't take long for the compressors to drain the battery beyond dead. So dead, I needed a new battery.
RossRinSD is offline   Reply With Quote
