Wheels for 67 C20
So today at a local town celebration car show I saw a 67 C20, similar to ours, except perfectly restored in great condition. It had american racing steel 8 lug wheels, in an 8-hole design. They looked really good on there, and since our truck needs wheels in a modern size (current stockers are split rims in 17.5"), Dad and I decided that those were the wheels we wanted. So, I was looking on Jegs and Summit, and these are the closest I could find to that. For $82 each + shipping, I think they're a pretty good deal. What do you guys think?
16 x 8, 8 x 6.5" bolt pattern with 4.5 inch backspacing. These will fit, correct? ![]() http://www.summitracing.com/parts/CRR-3987880/?rtype=10
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Between Trucks...
Re: Wheels for 67 C20
I had some Rockcrawler rims like that in black. 16" x 8" with 4.25" BS, 4.5" BS should work.
Beat it to fit, Paint it to match... ![]() |
Also, the truck I saw had 235/XXR16's, I'm thinking 245/75's would work well (stock size on newer silverado's). Anyone know what that is compared to 9.00 - 17.5 (IIRC, will check in the morning for sure) height wise, as in how far off the speedometer will be?
Try this link: http://www.miata.net/garage/tirecalc.html
That site only knows P-metric sizes. What is a size like 9.00-17.5 considered, as it's not "standard". I might just have to measure the height and approximate...
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A Last edited by ed2552; 07-12-2010 at 01:01 AM. |
Bueller?
Bump.
Between Trucks...
I'm running 265/70R16's and my speedo is pretty close to spot on with my GPS.
What was your original gear ratio and tire size?
Between Trucks...
4:10 gears. Don't have a clue as to what size tires originally came on the truck. It's a '69 C-20.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 07-13-2010 at 06:09 PM. |
Ok, thanks. I think a 265/70 is about 0.5% taller than a 245/75.
Location: Aurora,Il ..born,raised and still live in the same house
I have those exact same rims except mine are from "eagle" .
for 82 bucks you can't beat those 8 lug cragars! seriously I paid 150 for all 4 from some guy on craigslist,lightly used.
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL Last edited by beebster; 07-14-2010 at 12:00 AM. |
