I need more flex
I have a 69 K10, I slapped on a Rough Country 4 inch spring lift and tweaked it as hard as I could.
![]() ![]() I swear, the frame flexed more than the suspension. ![]() I need to be doing this ![]() |
Certified Hobbiest
Re: I need more flex
theres alot of things you can do to get more flex.
just depends on how much work you wanna put into it. you could do a 52" front spring swap,or a link/coilover front suspension, for the rear you could do a shackle flip with longer springs. |
Get some revolver shackles that will help, or swap to a link/coilover suspension. Leafs are not the best for flex. Coils and 4 link is what you need, and RC is a very entry level lift as it is, so I wouldn't expect to much.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
4 link costs lotts of $$$ but that's the ultimate route. Next check out getting some Deaver springs, call them up and tell them what you are looking for. You can have custom springs made as well. My buddy went to a guy in Colorado and had custom leafs made for his blazer, he sits at about a 6-8" lift but gets nearly 16" travel out of them. They are amazing.
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
some people who keep the leaf springs remove the main weight bearing leaf(s) to get some flex, its usually a trial and error way. but i remember a blazer getting some pretty good flex outa leafs like 12-14in believe he upgraded to 3/4 leafs so when he removed some the truck didnt sink. just a thought.
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l |
#6 | |
Your shocks are probably the biggest limiting factor here.
You obviously can't leave them off, but try disconnecting the lower ends and putting your truck in the same place...see what happens. If it does give you more travel that way, longer shocks will solve the problem, just don't go too long. That will limit the compression.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Gone to greener pastures
![]() Join Date: May 2007
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#8 | ||
"I ain't nobody, dork."
Straight spring lift only will not goive you the amount of flex you're lookin' for. Lots of extras like the revolver shackles and special shocks to keep from limiting travel. You'll need different drivelines too... with that much flex, you'll pull a driveline apart at the slip yoke.
Getting it back in on the trail is dang near impossible... Don't ask me how I know... ![]() Had to drive back home off a trail once with only front wheel drive, and the rear driveline removed... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
