Old 07-12-2010, 06:36 PM   #1
Andice
Andice's Avatar
Stupid Question?
Perhaps this subject has been discussed in the past. Or perhaps I am just plain stupid..... But what are the two short, flexible, approx 1 1/2 dia. "tubes" that exit the cab of my '64 SWB Fenderside and head towards the rear of the cab just below the fuel tank?
Andice is offline   Reply With Quote
Old 07-12-2010, 07:05 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Stupid Question?
I'm not familiar with what you are describing. Can you post a photo?
Old 07-12-2010, 09:45 PM   #3
Greg63
Enjoy your truck
Greg63's Avatar
His and hers p*ss'er tubes?
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 07-12-2010, 10:41 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Saw something similar on a camper conversion with dual saddle tanks hanging off the frame. Used the regular filler neck but diverted the fuel to each tank. There was no tank in the cab.
Old 07-16-2010, 03:08 PM   #5
Andice
Andice's Avatar
Here are two images of the flexible tubes exiting the bottom of my fenderside cab just below each end of the fuel tank. Any ideas about what these tubes are for?
Old 07-16-2010, 04:49 PM   #6
aerotruk63
aerotruk63's Avatar
Are they flush with the floor inside of the cab or do they go up higher than the floor? Do they have a markings, like something was attached to them inside the cab?
Old 07-16-2010, 05:12 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
They certainly have the appearance of being flexible exhaust tubing, but can't imagine the intended purpose unless it was some type of owner designed drain. Doesn't look like the type of tubing that would be used to carry fuel to a remote tank. Judging by the design of the clamp and condition of the tubes they have been on there a long time. It will be interesting to see if you have the only truck on the planet with these tubes, or if they are left over from some accessory or factory option.
Old 07-16-2010, 05:29 PM   #8
aerotruk63
aerotruk63's Avatar
They had a ice chest in the box of the truck. #1 tube was attached to the output of a fan that was plumbed in the ice. The #2 hose returned the warmed up air from the #1 hose, thus cooling the cab. Somewhat like how a Thermador worked but on steroids. Unlike the Cool Pack that hung from the dash, referred to as Crotch Air, the system was known as Butt Air. GM Accessories part # 3866676. The icebox was color coded to the main body color of the truck. Coleman was the supplier of the ice chests.
Conspiracy Theory and Urban Legend!
Old 07-16-2010, 05:52 PM   #9
aerotruk63
aerotruk63's Avatar
Dual exhaust ran down the outside of the frame. Two boxed in sections surrounded the exhaust tubes with a perforated inlet. The tubes in the pictures were connected to the outlet of the boxes that allowed the warmed air to supplement the standard heater?
Theory II
Come on, this is turning into a contest!
Old 07-16-2010, 06:10 PM   #10
blackmopar
Aerotruk, I challenge your theories on this particular truck, although Ive heard many a tale about Butt Air!
I believe if Andice does a Vin/Title search he will find his truck was at some point owned by a Mr. Marin or a Mr. Chong. These flex tubes were attached to a 'burn box' that sat atop the exhaust Y pipe. Theres a secret compartment in the bed floor, by where you could fill it with local greenery and hotbox on the go - Hey, man you gonna eat that hot dog?
blackmopar is offline   Reply With Quote
Old 07-16-2010, 06:12 PM   #11
aerotruk63
aerotruk63's Avatar
Lmao!
Old 07-16-2010, 09:37 PM   #12
aerotruk63
aerotruk63's Avatar
The square nuts on both sides of the support are for the rear seat tracks, so the tubing enters the cab between the seat at the back rest just in front of the fuel tank and the door.
Old 07-16-2010, 09:45 PM   #13
Andice
Andice's Avatar
These tubes are not flush with the cab floor. There is an approx 1/4 inch lip.
Old 07-16-2010, 09:49 PM   #14
aerotruk63
aerotruk63's Avatar
Has a full bench seat?
Old 07-16-2010, 10:11 PM   #15
Andice
Andice's Avatar
Original full bench seat with the original two-toned vinyl.
Old 07-16-2010, 10:52 PM   #16
aerotruk63
aerotruk63's Avatar
The guys at the autoparts store all agree, that tubing would not be good for a liquid. So the thought was there was a camper unit in the box and they used the tubing as conduit for air conditioning! Heating anything would have been easier with rubber hose and t's. Is the cab original to the frame?
Old 07-20-2010, 02:53 PM   #17
Malibob
Malibob's Avatar
Take a pic from inside the cab if you can. This "stupid" question sure has gotten a lot of interest, maybe not so stupid after all.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 07-20-2010, 05:06 PM   #18
aerotruk63
aerotruk63's Avatar
All the years I've been looking at trucks, different sizes and models, never seen this before! This is a great puzzle. Shall we assume this is a southern truck?
Old 07-20-2010, 08:33 PM   #19
lakeroadster
How about a place to discard that "stash" (brewski's or wacky weed or ??) as you are being pulled over by the police.
All silliness aside, perhaps it was merely a way to get air flow to circulate through the dash / kick panel vents and then out through the vent tubes? The working man's Astro Ventilation?
lakeroadster is offline   Reply With Quote
Old 07-20-2010, 09:48 PM   #20
Malibob
Malibob's Avatar
Von Dutch did that very same thing in one of his custom trucks. Maybe you got yourself a Von Dutch special there.
Flickr
Old 07-20-2010, 10:25 PM   #21
aerotruk63
aerotruk63's Avatar
Quote from Barracuda Magazine
"In front of the passenger's seat is one of the Kenford's more intriguing features -- a brass-topped tube with "Tube Le Dump" engraved on it. This tube is a beer can ejector designed by Dutch for a '66 Olds Toronado he used to drive. The tube leads to the road below, so Von Dutch could get rid of empties without having to toss them out the window while driving."
http://www.barracudamagazine.com/vondutch.htm
Old 07-21-2010, 06:42 AM   #22
Malibob
Malibob's Avatar
Yeah that is the one! Forgot the names
Flickr
Old 07-21-2010, 07:20 PM   #23
Andice
Andice's Avatar
I can take a shot of the tubes from inside the cab but it may be awhile because my focus is now on assembling the rear half of the truck. I picked up most of my bed panels this afternoon. This truck was originally sold by a GMC dealer in Amarillo, TX and has been in Texas since at least 1977. I would have to assume it has been here since '63 or '64. Thanks for the beer can theory but the tubes are too small in diameter.
Old 07-21-2010, 07:23 PM   #24
aerotruk63
aerotruk63's Avatar
If you run some water down the tubes, do they emit any odor?
Old 07-21-2010, 07:53 PM   #25
Andice
Andice's Avatar
The tubes are very much under the seat and hard to see from inside the cab. I have poked my finger around and they are not blocked by anything at this time. Could these tubes been a sort of protective sleeve for two fuel lines coming from spare fuel tanks mounted inside or underneath the bed of the truck?
