07-12-2010, 07:56 PM | #1 |
Converting steel floor to wood
What is involved in converting a 72 steel floor to wood, besides the obvious stuff?
1972 super cheyenne 1970 Suburb |
07-12-2010, 08:03 PM | #2 |
Re: Converting steel floor to wood
I'm glad you asked I have been wondering the same thing.
Mark 1968 C-10 SWB 307/munci 4spd/411possi 1986-1990 1972 Cheyenne-10 LWB 350/TH350 IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER U. S. Navy Seabee "CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard" |
07-12-2010, 08:06 PM | #3 |
Grandpa in the rustmobile...
me too lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-12-2010, 11:18 PM | #4 |
I'll start. Labor, you need a wood floor headgate and all the cross members including the main one on the rear. The cross members on a steel floor are attached to it, but are seperate and different for a wood floor.
72 Cheyenne Super 80 Silverado Blazer 2wd |
07-13-2010, 12:42 AM | #5 |
Money
There's an angle piece available to weld onto the headgate, but wood, bed strips, cross sills and so on will run $1000 or so. I decided I couldn't lift the steel bed floor and didn't want to lift the bag-o-money so I still have the nasty pitted, holy steel floor... Try Mar-K in Oklahoma. There's an ad at the top of the page probably because the word bed is in the posts... |
07-13-2010, 09:11 AM | #6 | |
Junior Member
My grandson is on a budget so he put plywood over the metal floor, stained it and coated it with a sealer. It will work ok for now and it looks ok. It just depends on what direction a person wants to go with their truck and the budget they have to work with.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-13-2010, 10:59 AM | #7 |
You can check my build thread out...there is info. and pics from when I did my conversion...Starts on page #4
http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Here are the Mar-K installation instructions: http://www.mar-k.com/GM_67-72_Short_...Conversion.pdf This is a list of materials needed: 1 Set Bed Strips 1 Set Bed Wood Boards 1 Bed Bolt Kit 1 Rear Cross sill 3 (short bed)Cross Sill 5 (long bed)Cross Sill 1 Reinforcement Strip (49-1/2") 1 Reinforcement Strip (72") 1 (single exhaust)Exhaust Heat Shield 2 (dual exhaust)Exhaust Heat Shield 1 Front bed panel or Adapter Flange Completed Bed w/ Hidden Bolt Strips:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 07-13-2010 at 11:01 AM. |
07-13-2010, 12:58 PM | #8 |
Ive been thinking about doing that to but couldnt figure how much it would completely cost, where were you going to buy the parts?
07-13-2010, 02:31 PM | #9 |
here's mine, hardest part was cutting out the steel floor
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-24-2010, 05:43 PM | #10 |
Kvn1011
how much harder would it be to make a raised wood floor??
btw jaros44sr and rackman those look awesome! Last edited by kvn1011; 07-24-2010 at 05:50 PM. |
07-24-2010, 05:48 PM | #11 |
Moderator
If you can find an original wood bed for parts, you can save a TON of cash on the header panel and x-sills.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-24-2010, 06:14 PM | #12 |
come take my rough wood bed floor and bring me your steel floor!!
