07-12-2010, 11:11 PM | #1 |
Suspension Question (again)
I know this has been covered numerous times but i want to make sure i understand. I have a 64 SWB 1/2 ton that is all factory stock. I want to convert it to 5 lug power disc brakes. However, i have some concerns about the track width. How much wider will the track width be after the conversion? I will be running 15x8 wheels. I plan to use the complete front and rear suspension from a 1968-1972 1/2 ton donor truck with 5 lug power disc brakes. Any ideas thoughts or suggestions?
Thanks, Zack |
07-13-2010, 01:23 AM | #2 |
Re: Suspension Question (again)
There are a couple of issues you may need to know about before you go parts hunting. First, front disc brakes weren't supplied as standard equipment until 71. 70 and earlier had drums all around. Second, 71-72 rear axles are 1-1/2" wider than the earlier rears. Unfortunately, I never measured the track width on the fronts to see if that changed at the same time as the rears did. Strangely, some 70s also had the wider rears, and these trucks had 6 lugs and no discs.
If it helps any, the rears are 62" and 63-1/2" over the drums. Ray Last edited by raycow; 07-13-2010 at 01:27 AM. |
07-13-2010, 08:47 AM | #3 |
Thanks Ray,
I found a 1972 that is complete with the 5 lug front disc brakes and the 5 lug rear end. I was thinking of changing out the complete rear end since it will bolt right back in place. I was also wanting to to the same on the front end, swap crossmember and all out. I just do not like the look where the tires are sticking out right at the edge of the fenders. Of course, 3/4" per side is not bad really. Maybe i can make of the 3/4" in the wheel rear spacing. Next Question: Is a 1972 (5 lug disc) front end the same track width as a 73-87 (5 lug disc) ? Also, If i keep my current stock suspension and i install the 6 lug spindles and rotors. Will that change the track width from stock? I know some think i am being a bit picky but I am very picky on this. I want my truck retain its original stock appearance. Thanks guys, Zack Last edited by CVA59; 07-13-2010 at 09:03 AM. |
07-13-2010, 09:32 AM | #4 | |
B) 71-87 have the same track width dimensions & are wider than 63-70 drum brake trucks. C) 6-lug spindles & rotors from what? Swapping from drum to disc increases the track width unless you use CPP's modular spindles specifically designed to minimize track width increase (@ a cost).
07-13-2010, 01:07 PM | #5 |
once you know that the width is different, youll always notice it. I was going to run 6 lug disc so I wouldnt have to change the rear but It got pointed out to me that the front end was now wider than the rear and It always bugged myu after so swap the front and the rear, youll be happier, as for width preference, play with the backspacing if you go aftermarket,
1967custom |
07-13-2010, 01:24 PM | #6 |
Thanks guys. I appreciate all the info. I may just stay with all my stock suspension and rebuild it. The older i get the more and more i prefer the original stock equipment, LOL.
07-13-2010, 01:32 PM | #7 | |
You must swap to the 71-87 spindles in order to use it, so you will end up with the same track width as the stock 5 lug trucks. The other 6 lug rotor is a factory part used on 88-98 3/4 ton "light duty" trucks. This one requires 88-98 spindles, and those require 3/4 ton lower control arms because of the ball joint size. I have no clue what the track width will be with this setup. Both of these swaps are covered in considerable detail in this rather lengthy but very informative thread. http://67-72chevytrucks.com/vboard/s...d.php?t=367260 I agree with you about not caring for the "tires sticking out of the fenders" look, but I think we are in the minority here. This look seems to be quite popular with a large segment of our hobby. Ray |
07-13-2010, 01:41 PM | #8 |
Increased track width is most apparent when running the same wheel/tire combo on the front & rear. If you stagger the F/R widths, the increase is easily hidden. 6-7" fronts w/some 8-10" rears & the right back-spacing & it won't be that noticeable.
07-13-2010, 02:17 PM | #9 |
If i stay with my stock suspension (which at this point i probably will). I just don't want to get away from a stock look.
1. Can i put power steering to my stock suspension? If so, what sector can i use? 2. Can i put power brakes to my stock drums? If so, what booster and MS can i use? Thanks, Last edited by CVA59; 07-13-2010 at 02:42 PM. |
07-13-2010, 02:53 PM | #10 |
I did both on my 67 no problem, If youre running a small block just find a doner. and the gear box from a doner as well up to 77. 78 and up went to metric thread, if you use this just get an adaptor from napa. brake mooster is easy too just get the set up from a doner up to 72 and it bolts right in, be sure and get the arm that hooks up to the pedal too
1967custom |
07-13-2010, 03:26 PM | #11 |
Active Member
Factory drum brakes are about 1/2" more narrow each side than factory disc brakes.
Danny Nix CPP |
07-13-2010, 03:48 PM | #12 | |
A 72 is the only year that will work for the brake booster? Thanks, |
07-13-2010, 04:07 PM | #13 |
Active Member
CPP makes booster kits for all years. The 6772 kit uses the same booster set up. There are many different part # steering boxes. All of them will bolt up the same. The differences are metric & SAE hose connections, and differnt input spline size & teeth count. CPP stocks all the varius sizes. You can also find adapters at several parts stores.
Danny Nix CPP |
07-14-2010, 06:17 PM | #14 | |
the frame on a 67 doesnt have the dimple on the frame for the lump on the gearbox so get a torch and a 2 pound sledge
1967custom Last edited by michael bustamante; 07-14-2010 at 06:18 PM. |
