Old 07-12-2010, 11:31 PM   #1
laplander
Question Front cab mount question
We're yanking the cab off of an old '67 and while the rear mounting bolts came out o.k., the front bolts are just spinning with the nut. Can I just hit them with a sawzall and get the leftover parts out after I get it yanked?
Thanks.
laplander is offline   Reply With Quote
Old 07-13-2010, 02:23 AM   #2
67chevy1series
67chevy1series's Avatar
Re: Front cab mount question
dont yank it be gentle with the 67 no but seriously any way when we did that to mine we had no problems well besides extreme elbow grease
67chevy1series is offline   Reply With Quote
Old 07-13-2010, 05:33 AM   #3
JimKshortstep4x4
Have you tried holding the head of the bolt?
Some of of the bolts were welded in but I believe not all. The weld can break but I have been able to grind the bolts enough to get a socket on them.
If the bolts are good they can be worth saving as they are a 9/16" thread.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-13-2010, 07:13 AM   #4
gkesseru
gkesseru's Avatar
The rear nuts are welded in, but the front have loose nuts located under the carpet.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
