VA72C10
![]() Join Date: Mar 2008
Help identifying parts please
I am getting ready for final assembly....going through the boxes and bags of original parts and found these unlabeled... Some look to be jack and/or spare tire parts but since I've never disassembled a blazer (only a few trucks) I'm not 100% sure and not sure where they'd go. also not sure on the two large bolts with rubber grommets both sides....were they possibly suspension parts that weren't re-used with the lift kit put on? thanks...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
GEARHEAD
Re: Help identifying parts please
The blue parts are definitely the jack hold down pieces. No idea on the big washer, possible for the behind the seat spare tire holder. It might be the always missing part that goes on the hub of the wheel. The other bolts and bushings must be for leaf spring shakles or something like it.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#3 | |
VA72C10
any idea on the one big clip on the lower left corner?
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 07-13-2010 at 08:58 AM. |
GEARHEAD
I don't recognize it. Could it be for holding the heater hoses together? Looks too big to be for any brake or fuel lines, I don't think it's for any wire harness. If it's for A/C hoses I have no idea. I never had a truck with A/C.
GEARHEAD
I'm thinking the shackle bolts are probably the ones that hold the rear spring shakle to the frame bracket. If the springs were replaced they might not have pulled those out to save time, and just did the spring bushings.
#6 | |
VA72C10
the clip on the lower left looks like the ones I had on my suburban that held the AC or trans cooler lines.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
Used Register
I'm also thinking the clip is a heater hose hold-down. Snaps in a hole on the passenger side inner fender well.
The blue brackets and springs are jack hold-downs. The boly to the vertical wall of the step up to the bed, behind the seat (driver's seat I THINK). I don't recall the arrangement, but on hook engages the circle on the end of the spring after it get stretched over the jack. The other end of the spring is bolted down and the sring runs side-to-side across the area behind the seat. The washer is the spare hold-nut part that covers the large hole in the rim. There is a J-bolt that hooks into a strap on the spare tire bracket and a big wing-nut that screws onto it. The washer spreads the clamping force of the wing-nut over the big open center hole. edit - here's a link on the board to the set-up on the jack hold down. http://67-72chevytrucks.com/vboard/s...ight=jack+hold Last edited by herb101; 07-13-2010 at 03:25 PM. Reason: added info & link |
The blue pieces are to hold down the tire iron behind the drivers seat on the step-up.
![]() Join Date: Dec 2002
The one clip snaps to the top of the inner fender for the heater hoses
Bingo!
VA72C10
Thanks everyone...I'm going to save the jack and spare tire/spare parts for the next owner...and will clean up and install the heater hose clip once I put the inners in...
