Old 07-13-2010, 03:00 PM   #1
storked82
storked82's Avatar
Wanting to know/how to smooth your fire wall
HI GUYS
I need a little help Im wanting to take out my heater blower motor ect To clean up my fire wall/I have never done anything like that before and was woundering what all is involved this is on an 82 silverado PLEASE I NEED PICTURES Also do they make a plate to cover up the hole? and do you leave your heater coil in ?
Thank you guys you are the best
Jeff Main
storked82 is offline   Reply With Quote
Old 07-13-2010, 03:25 PM   #2
dv8customs
dv8customs's Avatar
Re: Wanting to know/how to smooth your fire wall
As far as I know there is no one making filler plates for your year model firewall. If you don't plan to keep your heater then you would need to remove the heater core, otherwise you are going to have the inlet and outlet sticking out of your firewall for no reason.
dv8customs is offline   Reply With Quote
Old 07-13-2010, 04:18 PM   #3
nrider
I've actually been thinking of this too. I really don't need air or heat but I'm wondering what all is involved. How far have you gotten with this project storked?
nrider is offline   Reply With Quote
Old 07-13-2010, 04:22 PM   #4
silvereagle07
silvereagle07's Avatar
There are some trucks in the build thread area with smoothed firewalls with pics.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 07-13-2010, 05:26 PM   #5
storked82
storked82's Avatar
Rider
I havent started on it yet LOL I was woundering how much is involved in doing it? Im the type that needs pictures or hands on to beable to do it lol
Some one can tell me all day long and I just dont get it I guess that comes with age or? I just dont like the looks of it just hanging there and not hooked up I hope some one out there can shine some light on this for me
Take care Rider and good luck on yours
Jeff Main
Old 07-14-2010, 08:45 AM   #6
nrider
Thanks you too. I think it just comes with experience and not being afraid of tearing something up, something I've been working on here lately. I'm hopefully going to start a build thread this weekend and I'll put up pictures if I give it a try. Oh and btw, are those metallic blue flams on that c10, they look real good.
Old 07-14-2010, 10:37 AM   #7
storked82
storked82's Avatar
n rider
Those flames on my truck are purple.The paint came from Napa and is VERY expensive .It is made by semour I cant think of the last name The yellow is called banna yellow and it came from Napa also That would be cool if you take pictures of you removeing the heater ect to smooth out the fire wall .
Take care
Jeff M
Old 07-14-2010, 12:19 PM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
I just used a piece of sheet metal
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-14-2010, 03:48 PM   #9
Dropped84GMC
Dropped84GMC's Avatar
i know alot of people around here on racecars and such just use a peice of sheetmetal and paint on their club name or anything else just for a little touch..
1984 GMC 1500 2WD
Big plans in the making
Dropped84GMC is offline   Reply With Quote
Old 07-14-2010, 03:59 PM   #10
MONTEZ
Make a template and transfer it to a piece of sheetmeat around 16 ga would be fine. Fit it to your fire wall. Mark places to drill the sheet metal for tack spots. Take it back off and drill the tack holes. Fit it back to the fire wall and tack it on. Fill all tack holes with weld. Grind smooth. Finish with putty. Sand and paint.
In a nut shell.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 07-14-2010, 06:41 PM   #11
3r!c84
Badass
3r!c84's Avatar
wheres your wires flamming10
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-17-2010, 09:28 PM   #12
Lonnies Performance
Lonnies Performance's Avatar
I built one out of 12ga so it would remain totally flat without distorting & welded studs to the rear so it bolted in through the existing firewall holes.
Tried to do this without cutting up the factory firewall so it looked factory.
Lonnie Pavtis
'82 Duramax Conversion in progress
Lonnies Performance is offline   Reply With Quote
Old 07-17-2010, 09:52 PM   #13
Rogue_Sentinel
Rogue_Sentinel's Avatar
Porterbuilt Street Rods make one for the 67-72 firewalls,trying to get him to make one for the 73-87
http://c10forum.com/forum/showthread.php?t=5680
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final."
Hunter S THompson
Rogue_Sentinel is offline   Reply With Quote
Old 07-18-2010, 07:02 PM   #14
storked82
storked82's Avatar
Thanks Guys
For the pictures and info I wish someone would make these to fit 73-87
Im not good at fabercating LOL My truck is going to the body shope on the 26 of this month to have the door jams repainted and some touch up work So after that is done I might try and see if I can tackel this on my own
Keep the pictures comeing
Jeff Main
Old 07-18-2010, 09:24 PM   #15
flamingbig10
6.0 powered square
there hidden except for the wiper motor wiring, the wires are routed through the floor board by the emergency brake cable
Aaron
Old 07-19-2010, 10:35 AM   #16
blazer2007
I did mine with a piece of sheel metal and weld in some threaded studs on the back side and used adhesive around the edges so no water would get in and siliconed around the edges that was paintable from a paint shop[need special stuff] and if I ever decide to put heater back in can take the panel out,was very easy ,just use cardboard template and a grinder
blazer2007 is offline   Reply With Quote
Old 07-19-2010, 11:42 AM   #17
ERBSIX
ERBSIX's Avatar
No heat or A/C? Are these all trailer queens?
I think Vintage Air is going to be the only way for me to go.
Their system is incredibly small for what it puts out.
Of course, everything is under dash, but that's easily hidden.
Makes the engine bay look very clean with just those 4 hoses running into the firewall on the passenger side.
Truckin did a great article on a Vintage Air installation in the Pickup Fixup Tour.
Here is a pic of the firewall. The four hoses on the left are all you need.
Very clean, neat and easy. That's what I want. But it's also pricey.
Related Truckin Article
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 07-19-2010, 01:01 PM   #18
ERBSIX
ERBSIX's Avatar
Here is another example of a very clean vintage air under hood setup.
Old 07-19-2010, 02:24 PM   #19
ERBSIX
ERBSIX's Avatar
To be back on topic:
User smokedat has some great pictures of how he created a paper mockup and cutout a firewall cover from sheetmetal.
First post on this page:
