454 MAKES IT ROAR
Guys! just wanted to ask if there was anything that can be done to improve the turning circle on our Trucks? ie steering upgrades or adjustments?.....I have a standard power steering unit on there, 4 turns lock to lock.
Do your wheels stick out any further on full lock than mine? ![]()
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Re: Steering question
smaller diameter front tires give better turning radius
454 MAKES IT ROAR
That makes sense cd, but it's not like they are hitting the inner fenders on full lock or rubbing anywhere for that matter. Can anyone take a look at their wheels on full lock and let me know if mine look about the same?
I turned the wheels out to full left as your picture and could not see any difference. I am not sure if the comparison is definitive. Do the stops come into contact when the wheels are fully turned?
My only other thought is to check the drag link to make sure that is installed correctly. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#5 | |
454 MAKES IT ROAR
![]() But an even bigger problem has come to light I spotted a crack in the frame where the steering box bolts on, had my wife turn the wheel to see what was going on under there an it looks like it's about ready to tear loose. ![]() ![]() ![]()
454 MAKES IT ROAR
Once I strip everything off, will just welding the cracks be strong enough or should I have a piece of metal welded to the inside of the frame to support it ?
Amazed Member
![]() Join Date: May 2010
holy mackerel, its moving a lot. better get it fixed asap. i would back it up with a plate inside. whew, good thing you caught that!!!
![]() 1950 3100 Original Project! |
member #16
![]() Join Date: Dec 1999
Yikes!!! x2 on the plate.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
454 MAKES IT ROAR
Thanks guys....This has now become my priority job, gonna start stripping it down tomorrow to get a better look.
Any thoughts on why my bump stops don't touch on full lock? can I adjust something?
member #16
I think they will when you get the frame fixed. The frame was flexing too much.
#11 | |
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
-Ron- ![]() |
Holly Crap, I think I am going to go look at my Sons trucks now that Ive seen that. WOW.
JRBECK64 |
#13 |
Some of the 4x4's came out with a reenforcement that fits inside the frame. If you can locate one and install it along with welding your frame you will be good to go.
Jim PS: I have not seen a truck frame that was cracked up that much! Good thing that you started looking at your problem.
#14 |
Between Trucks...
That scared the pi$$ out of me. Off to check my frame.
Beat it to fit, Paint it to match... ![]() |
#15 |
Cruzin
CRAP -O, thats crazy, good thing you thought to ask this ? or you might not have caught it in time
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
