Old 07-13-2010, 09:11 PM   #1
C10Silverado79
Carb vacuum leak - best way to seal?
I seem to have a vacuum leak at the rear of my carb where it mounts to the manifold. The carb was rebuilt, the gasket is new and the bolts are torqued down properly. The front seems to be fine but the rear definitely has a leak. What is the best way to seal the leak? Add some gasket sealer? Go for another new gasket? Something else?
1979 C10 Silverado
1998 Camry 5spd
2005 Harley ElectraGlide
C10Silverado79 is offline   Reply With Quote
Old 07-13-2010, 10:41 PM   #2
GMC Guy
GMC Guy's Avatar
Re: Carb vacuum leak - best way to seal?
maybe try adding a couple thin gaskets? just an idea.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 07-13-2010, 11:08 PM   #3
cableguy0
What kind of carb and intake is it? If your using a sqaure bore carb with a spread bore manifold such as an edelbrock performer with an edelbrock or holley square bore carb your supposed to use the square bore adapter plate to ensure a good seal.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-13-2010, 11:30 PM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
by what means are you declaring it's a carb leak?
if you are spraying WD-40 or anythin like that back there to see if there's an idle change you might want to explore the rear gasket on your intake.
when you pulled the carb last did you inspect everything make sure all lines not in use are capped etc?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-14-2010, 07:19 AM   #5
C10Silverado79
Sorry, It's a stock Q-jet 4bbl. I put a new gasket on when I rebuilt the carb a month or 2 ago. I also replaced all the vacuum lines. Yes, the idle increases and smooths out when I spray some carb cleaner around the back of the carb (near dizzy) where is mates to the intake manifold. I had cleaned both surfaces before putting the carb back on.
1979 C10 Silverado
1998 Camry 5spd
Old 07-14-2010, 08:29 AM   #6
silvereagle07
silvereagle07's Avatar
I'd go for the new carb gasket. But check with a straight edge to see if the manifold or the carb base is distorted. The should not have much clearance at at all.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 07-14-2010, 11:03 AM   #7
ron350
ron350's Avatar
Is it possible you used the wrong base gasket for your carb?
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 07-14-2010, 02:53 PM   #8
C10Silverado79
I'm not beyond making a mistake so it's possible. i know I tried to match the old gasket with the new ones to get the right match. I guess I'll get a new one and see if that solves the problem.
1979 C10 Silverado
1998 Camry 5spd
Old 07-14-2010, 03:09 PM   #9
p_rubottom
p_rubottom's Avatar
Kinda a shot in the dark here but could run a bead of gasket maker on your paper gaskets you have installed already just to make sure theres a good seal?
p_rubottom is offline   Reply With Quote
Old 07-14-2010, 03:53 PM   #10
Dropped84GMC
Dropped84GMC's Avatar
what i do is run over the gasket areas with a sharping stone just to smooth and level them out ... my advice is to buy a new gasket and do what i said above and see if your problem is fixed ... also i would put a rag in the intake manifold and use a vaccum cleaner to suck out all the little chips from where you sand the intake manifold
1984 GMC 1500 2WD
Big plans in the making
Dropped84GMC is offline   Reply With Quote
Old 07-14-2010, 03:54 PM   #11
cableguy0
Rtv should not be used on a carb gasket. As stated make sure the surfaces are flat and make sure your using the proper gasket and theres no reason it shouldnt seal.
Old 07-14-2010, 04:03 PM   #12
irishman999
irishman999's Avatar
My quadrajet has a pretty strong baseplate, im not sure if it would warp easy but i've seen carbs that got overtightened and it warped the baseplate, in that case i would secure the carb in something like a vice, wrapped in a towel and file the bottom with a large bastard file.
irishman999 is offline   Reply With Quote
Old 07-17-2010, 12:01 AM   #13
C10Silverado79
I'm pretty sure I resolved the vacuum leak. I decided to poke around a bit before i tore the carb back off. Turns out the diaphram in the EGR valve is shot. Since the valve sits right next to the carb I think it was picking up the carb cleaner when it sprayed. I disconnected the valve and capped the line. Carb cleaner made no change and vacuum is steady. I don't know if I'll replace the EGR or just leave it disconnected.
I still have to solve my problems when motor is under a load. My first thought was the it wasn't getting enough fuel. I'm starting to think it's "Fuel Spewing" instead but I'm not sure how to fix it.
1979 C10 Silverado
1998 Camry 5spd
Old 07-17-2010, 05:06 AM   #14
dammitmitchell
the pollock
fuel filter first
Army vet 02-08
Old 07-17-2010, 10:01 AM   #15
68 TT
Still plays with trucks
68 TT's Avatar
It is possible you set the float level too high when you rebuilt it. Kind of a pain to readjust on a Q-Jet.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-17-2010, 02:43 PM   #16
C10Silverado79
Certainly not 'IMPOSSIBLE'. I'm going to triple check everything else first before I pull the carb apart again. I went back and read some more in my Doug Roe book which is why I'm leaning towards fuel spewing more than fuel starvation.
1979 C10 Silverado
1998 Camry 5spd
