![]() Join Date: Feb 2008
Anyone know any shops in the NO/Gulf Coast area that does bags?
I called a shop here local about 2 weeks ago.....the guys said he was going to do some research and call me back. NO call.
I called today, they had the installer call me...he said Ill call you right back with your options/prices.....NO call.. If these guys cant even call back, Im not sure I want to give them my truck or $$$$ Anyone know of any shops or anyone that does bags in South Lousiana---> Panama City area??? Thanks! |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: Anyone know any shops in the NO/Gulf Coast area that does bags?
Air bag suspension is very easy to do on trailing arm and a arm suspension.just take your coil sprigs out of the back and bolt your cups and bags in.front you will need to bolt a upper plate in and a lower cup and presto.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
yeah that wouldnt be to bad....but Im looking to either lay frame or get damn close!
I might just do it myself if I dont find someone soon....I think Id get more satisfaction from that too....there's so much help on here, Im sure I can do it |
if your talking about laying frame there is a lot to consider.here is a pic of my truck on bags with 2" drop spindles and no notch.
#5 | |
www.dropmember.com
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-13-2010 at 11:14 PM. |
man I wish I could AFFORD that.....to bad the Air Force doesnt pay me those kinds dollars! I just saw his specials...and although their GOOD, I still cant swing it!
Maybe one day when I get a real job! LOL |
Bag it and drive it.dropmember later.
Most pro shops are going to charge you a similar amount to allow your frame to lay. Baby steps.... Do the bags & mild drop now (yourself) & maybe the DM later.
i agree. i had quotes of over 5grand to lay my 68. i saved the money and went with nates products front and back. u dont want to go cheap on something so permanant.
no offense, but if you can't afford doing it the drop member / raised cross member way then you're not gonna be able to afford to pay a custom shop to do it their way.
Junior Member
MudHole
504-469-6382 |
shane is correct, buy the porter stuff once and be done with it. i used several shops here in houston and spent top dollar and still was not happy. you are going pay about the same amount of money on porter parts and then you can brag to your buddys that you built it.
