let's talk radiators
So my next big purchase is going to be an aluminum radiator. I have looked at quite a few of them and priced them out. I am looking for the best aluminum radiator for a decent price. I dont want to spend "be cool" kind of dollars, but want a quality radiator that performs well. I was looking at the entropy radiators on e-bay, but so far nobody has been able to give an update on how they perform. I also see they may require a little moification to fit properly. I plan on running electric fans. What are some suggestions from your experiences?
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
![]() Join Date: Jul 2009
Re: let's talk radiators
Why not just a 4 core oem. Most say the cool just as good
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
for a regular driven daily driver mild 350 no need for an aluminum rad as they're way overrated as well as pricy// 4core OEM is good if you're doing alot of heavy towing, in reality best bang for the buck is OEM 3core, i used one for years with a mild(300hp) 350ci with ac with the truck loaded up for swapmeet weekends never had a problem with overheating even on days approaching 100 degree in stop'go backups on the freeways
where is a good place to look for oem 3 or 4 core radiators? Have any recommedations for fan set ups?
I have a 307 with a 4speed granny and a rear end for pulling, i have a stock radiator and drove my truck 350miles in 90degree weather and i was running between 75-90 miles an hour(moslty over 80)and my truck stayed amazingly cool i couldnt believe it. If you want it to run cooler try switching your whole truck into ams oil, my brother in law did that an his cars ran a lot cooler an got better mph. Im switching out my car this month so im going to see how it affects me.
i'd check local autoparts store or air conditioning shop// google radiator with your location
as far as fan i stuck with the factory setup// shroud is very important, then the clutch setup for the fan too
I need something that will keep the truck running cool in 110 degree weather in stop and go traffic with the ac running. I know electric fans should take care of the stop and go traffic part. Its not that hot everyday here, usually in the summer we average mid 90's but one day last year, or the year before, it was 114. It seems that every old car I have ever owned without electric fans has overheated in stop and go traffic and then as soon as I get some speed up and air flowing the temps would drop back down. Never had a problem with this truck before but Im not sure what temp it ran at.
#8 | |
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Junior Member
I have a 454 in my '71 and it stays real cool with a 3 core radiator from Auto Zone and stock fan clutch setup. I am sure other parts stores have similar radiators.
The 454 in my '92 GMC use to have problems in stop and go traffic until I mounted a couple of pusher fans in front of the radiator. I have not looked to see if any would fit in front of my radiator on my '71. If you decide to go with electric fans only, remember you have to have a high enough amp rated alternator to run them.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
I busted the side out of my OEM radiator and so I bought one of these and it works great/ looks great and its cheaper than an OEM or one from the local parts store and it is all aluminum.
What I like about the aliminum, is if you ever punch a hole in it, you can just weld it right back up and keep on truckin. http://cgi.ebay.com/CHEVY-TRUCK-ALL-...item3f016b559e |
![]() Join Date: May 2002
OEM 4-cores are the way to go for cooling. I have a stock 350, with a 4-core and it keeps it very cool even with the A/C on. When I lived in DFW, I could run the A/C the whole day, and the temp would never get above the first hash mark on the temp gauge. When I had to replace it, I bought one from Advance Auto online, was about $165, and had free shipping to boot.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Why don't you find a good local rad shop and have your rad recored. You can have it made to your specs. And you know it will still fit. JMHO
#13 |
Under Construction
if you want to go aluminum, contact this guy, alot of members are running his setup for 67-72 c10's with shroud and dual spal fans with no issues.....
http://motors.shop.ebay.com/entropyt...1&_from=&_ipg=
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 07-14-2010 at 03:49 PM. |
#14 | |
#15 |
I bought an aluminum racing radiator. I figured if it would keep my race truck cool it would work for a stock 350, I was in bumper to bumper traffic at 95 degrees on the 4th and had no problem. In fact it almost runs too cool. I think I paid $209 for mine and it fit with very little modification. All I had to do was drill out a rivet and move one lower mount a little and pop rivet it back in. I am running a stock 6 cylinder shroud and stock fan.
#16 |
I have been running this rad and really like it so far. 3 core rad brackets (top and bottom) need to be used.
http://cgi.ebay.com/ebaymotors/1968-...item5adad62b56 |
#17 | |
#18 |
It has worked well so far. The transmission cooling connections are well placed as is the lower hose connection. I don't know why it is so much more inexpensive than the other aluminum radiators though.
#19 |
I went ahead and bought one of these today. For the price it seems like the best deal. An OEM replacement would have been just as much. Next up I am going to configure a fan set-up. Thanks for all the input!
#20 |
Under Construction
let us know how it works out....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#21 | |
Never Ending Projects
![]() When I got it, it was well packed and looks like a very high quality piece. Hope to use it one day.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#22 |
my 72 burb 3/4 ton 2wd has a 307, 3 on the tree and no a/c, but i still wanted to replace the dinky 2 row with a 4 row. i found the best price on a brand new factory style 4 row from Jim Carter. cost was 200 bucks plus s/h....cheaper than any other vendor i have found. They have stopped stocking parts for 67-72 chevy trucks (too much competition) but they may still have some radiators in stock.
oh.....and my dad had kept the 7 blade fan from his 72 burb and i installed it on mine to replace the standard 4 blade. i also installed an overflow bottle and put in a 180 deg thermostat. Last edited by capev86; 07-20-2010 at 04:46 PM. |
#23 |
dazed and confused
wow i would like to get one myself. let us know pips how it works out.
members met: redbaron69, billsbowtie,nc67 |
#24 |
I'm running a Heavy Duty radiator (I think its the 4 row core yall talking about). I have it in combination with a flex fan and a shroud and that thing will never get far off of cold even in this Florida weather.
#25 |
anyone have any suggestions or experience with electric fans and which quality is better. Here is the two that I am looking at. The SPAL set up is more expensive, but again I want to make sure I get a quality product. If anyone has any experience with the jegs set-up please chime in. I want a good product but dont want to break the bank.....
http://www.jegs.com/i/JEGS/555/52116...ductId=1014845 http://www.spalusa.com/store/main.as...&item=30102052
