Old 07-14-2010, 12:05 PM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Unhappy Motor Oil in Vaccum line from Carb to Distributor? Need help to stop this
Hello once again I have come to problem that I think needs some attention fast, and I want to fix it before it ruiens my Distributor. I am running a 454 with Proform 67200 - Proform Race Series 750cfm Carburetor & a MSD Digital E-Curve Pro Billet Distributor on a weiand Intake Manifold. I noticed oil coming out of the vaccum line when I went to change it .(Yes the oil is in the line I blew into the new line after a few more miles of driving it and more oil came out. Why am I getting oil in that line and how do I stop it before I ruien my Distributor? Please help... I also think it is causeing my my carb to sputter when I get on the gas. Thanks again in advance....
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-14-2010, 12:17 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Motor Oil in Vaccum line from Carb to Distributor? Need help to stop this
Where do you have the vacuum line connected to other than the distributor? It should be hooked to the carb on a vacuum port and there should be no way any oil can get there.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-14-2010, 01:11 PM   #3
petey-pablo
"THE GREEN GOBLIN"
That is exactly Where I have it hooked up. I will take a close up picture and post it..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-14-2010, 01:23 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
post a picture of where you have it connected. If you have it on the carb above the throttle plates then you may have whats called reversion. Its where air/fuel/oil mix comes back out of the carb usually due to severe blow by or a leak in the intake manifold gaskets allowing oil into the runners.
dwcsr is offline   Reply With Quote
Old 07-14-2010, 01:31 PM   #5
rollinhard
rollinhard's Avatar
Ive seen this on our stock car were the seal in the dizzy goes and lets oil up top. pull the cap and see if theres oil in it i bet thats your problem. The vacuum is actually pulling the oil through your dizzy.
Just a thought Curtis
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 07-14-2010, 01:51 PM   #6
petey-pablo
"THE GREEN GOBLIN"
ok heres a picture of where I have it hooked up to the Carb it is circled in red. and the other pictures are of the oil I blew out of the line...
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-14-2010, 01:58 PM   #7
petey-pablo
"THE GREEN GOBLIN"
I do have a leak in the back of my intake manifold that I have tried to fix once and it came back then took it in to get fixed and it came back Now I am about to take it in for a third time to get fixed on Friday. Do you think that is my problem sounds almost like what you explained above?
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-14-2010, 02:02 PM   #8
petey-pablo
"THE GREEN GOBLIN"
I will pull the cap and check Im convinced it's comming from the carb end though. Thanks
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-14-2010, 02:15 PM   #9
dznucks
dznucks's Avatar
i have a similar problem but its fuel in the same vacuum line. it only happens when i run my demon carb. it wont happen with the edlebrock.
i used to get oil in the bottom of my dizzy, but that was due to an incorrect PCV valve.
dznucks is offline   Reply With Quote
Old 07-14-2010, 02:30 PM   #10
petey-pablo
"THE GREEN GOBLIN"
I thought it was fuel at first when it was alittle, but after I took the hose off found out it was oil I ran a black light over it and it glows, I have dye in my oil ..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-14-2010, 05:09 PM   #11
petey-pablo
"THE GREEN GOBLIN"
Taking the Cap off was no help niether! it's all digital, heres a picture...
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-14-2010, 06:14 PM   #12
geezer#99
geezer#99's Avatar
I know I'm old and I've got bifocals but for the life of me I don't see a vacuum canister on your dizzy. ?????? So what line is it.
Old 07-14-2010, 06:50 PM   #13
hotrod100
hotrod100's Avatar
The vac. advance is under the electronics plate. Here is a cutaway view of it. The only way I can see oil getting in that hose is if the advance unit is leaking and causing the dizzy housing to go into a vaccum which will also cause oil to pull up through the seal.
My build thread.
hotrod100 is offline   Reply With Quote
Old 07-14-2010, 06:59 PM   #14
geezer#99
geezer#99's Avatar
Nice pic. So where does the vacuum hose hook in to it?
Old 07-14-2010, 07:08 PM   #15
hotrod100
hotrod100's Avatar
It hooks to the silver barb that points down out of the bottom of the dizzy just to the right of the cutout.
My build thread.
Old 07-14-2010, 07:14 PM   #16
geezer#99
geezer#99's Avatar
Merci!!! I have been educated.
Old 07-14-2010, 07:25 PM   #17
Zeke
Active Member
Not sure but it looks like the vacuum could be pulling oil up through the distributor shaft and you would never know it. Have you put a vacuum on the distributor to make sure the diaphragm is still good in the canister?
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 07-14-2010, 07:35 PM   #18
fixit-p
fixit-p's Avatar
It's just a vacuum transducer and not a can as we all know and love and since vacuum sucks I agree with all that it's coming from the dizzy and not the carb.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-14-2010, 07:47 PM   #19
rollinhard
rollinhard's Avatar
With the electronic board on top it would be hard to see if there was oil in the bottom.
Old 07-14-2010, 09:27 PM   #20
71 super
71 super's Avatar
You are pulling vac. from a constant vac. source below the plates of the carb. Because you are at a constant vac. source and the dist. uses engine oil for the bushings it is possible that since it is a fresh motor and after seeing burnout video and listening to it is pretty healthy(ie good rings high oil pressure etc.) you are pulling oil up past the seals in the distributer. I would put the vac. advance on a PORTED source above the throttle blades and see what is happens. If it does not stop, the seals within the distrib. are gone and need to be replaced to start with.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-14-2010, 09:42 PM   #21
eagleuh1
eagleuh1's Avatar
What brand distributor is that? Never seen one quite like that before. Good find on the cutaway drawing.
eagleuh1 is offline   Reply With Quote
Old 07-14-2010, 10:12 PM   #22
fixit-p
fixit-p's Avatar
If the oil is coming from the dizzy (which is the most logical source) then it's more than just the seals that are bad because the vacuum transducer would have to have a leak
Old 07-14-2010, 10:31 PM   #23
fdbdw
fdbdw's Avatar
Ive never experianced this issue but common sense would lead me to believe that because vacum is being pulled in the direction of the carb that the oil would have to be comming from the dizzy, if it was comming from the carb then the oil would have to travel against the flow of vacum and toward the dizzy, just a thought
fdbdw is offline   Reply With Quote
Old 07-15-2010, 08:22 AM   #24
KEL
72 GMC
KEL's Avatar
Smile Re: Motor Oil in Vaccum line from Carb to Distributor? Need help to stop this
One of the few things I learned in high school is that
"vacuum doesn't suck, pressure blows".
KEL is offline   Reply With Quote
Old 07-15-2010, 09:57 AM   #25
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Are you running a PCV to help even out the pressure in the engine? I also see a "T" in the line in your pic of the carb. Is the vac line from the carb "T'd" into anything else? You should only run the vac to the distributor and nothing else.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
