Sanitizing a 71 C10 with a mishmash of engine parts
I need some help in figuring how to sanitize a truck that I inherited from a family member.
Basically, it is a 71 C10. It has a THM350 for the tranny. The engine is a curios case. The truck originally had a 350. However, the engine died and it was replaced by a 305 from a 76 chevy nova. But wait there is more. Evidently, the manifold and carb of the 305 was replaced by a manifold and a two barrel carb off of a 350. I am sure that the carb is off of a 350, I'm not sure about the manifold. The truck makes terrible gas milage - approx 10 mpg. And is not drivable until the engine gets really warm. So, would like to replace the manifold and carb with something more suitable. The problem I have is that up here in the north east, it is really hard to find trucks of this vintage. So I figure I will just have to buy a new manifold and carb. The goal is to get better gas mileage and improved drive-ability. Improved acceleration would be nice. Any suggestions on the manifold/carb combination? -David |
Junior Member
Re: Sanitizing a 71 C10 with a mishmash of engine parts
do not expect much better than 10 mpg's no matter what mods you make
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Between Trucks...
Maybe an Edelbrock 1403 and Performer EPS intake. I wouldn't expect miracles in the MPG department though. These trucks are heavy and have the aerodynamics of a brick.
Beat it to fit, Paint it to match... ![]() |
With a 305 and 4bbl I have gotten 15 or so on the highway. About the same with a 350 and 250 I6. A 1406 will be OK on a 305 and the electric choke will help on the cold starts.
GM made two sizes of 2 barrel carbs (different base bolt patterns) and I believe 350s got the big one. You would get better gas mileage by going to a Q-jet if you have the will power to keep your foot out of the secondaries.
Ray |
