Old 07-14-2010, 06:00 PM   #1
Davidmichael
Davidmichael's Avatar
Rear heater lines
I have searched with little luck, and when I call the auto parts store (couple of them) they either do not carry or have no idea what I am talking about.
Anyone know where I can look to buy a set of antifreeze lines that go the length of my truck, or do I have to custom make the lines?
Davidmichael is offline   Reply With Quote
Old 07-14-2010, 07:25 PM   #2
TheApocalyptican
TheApocalyptican's Avatar
Re: Rear heater lines
If they are just lines like are used to connect the front heater core, you should be able to find them at a local parts store. Most of the local places here call them heater hoses, not heater lines....just an fyi. My only concern would be finding one who has enough length of it in stock.
If they are some type of hard line(I personally don't know what the stock rear heater lines look like, as my Sub has an aftermarket rear heat)then hopefully someone else can help.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 07-15-2010, 01:36 AM   #3
Davidmichael
they are metal hard lines. they are pretty rusted and yesterday I got a leak in the rear. I wish they were just hose. that would be an easy fix.
Old 07-15-2010, 01:47 AM   #4
TheApocalyptican
LMC has 'em, but they're not cheap. Also as a last resort you could convert to regular heater hose.
Old 07-15-2010, 03:00 AM   #5
Davidmichael
wow. I was not thinking they would be that expensive. oh well. just have to find some hose and convert I guess.
Old 07-15-2010, 03:12 AM   #6
TheApocalyptican
LMC is usually high priced for a lot of their parts. The good news is....usuallly, if LMC has 'em, then someone else will have 'em for cheaper.
Old 07-15-2010, 07:31 AM   #7
Davidmichael
thanks a lot. at least now I am heading in the right direction
