someday
![]() Join Date: Dec 2001
16 electric fan, summit trans cooler, holley 650
1: 16 inch hayden from summit electric cooling fan i used this for about 6 months works good. $20 plus shipping
2: Trans cooler from summit i dont recall the brand no dents or leaks $25 shipped 3: Holley # 4777 carb 650cfm bouble pumper square bore was rebuilt right before i took it off about 3 or 4 years ago probably needs a good cleaning $50 shipped
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
Re: 16 electric fan, summit trans cooler, holley 650
sent you a pm you can ignore. coudnt get thread to open earlier. choke and secondaries both mechanical?
Its Topless Season!!!!
Questions on the fan....what is it applicable to? push or pull? what did you have it installed on?Engine size? did you have any problems with it...reason for removal? thanks
I will take the fan, if it works.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
someday
rich67, The carb is manual choke and mechanical secondaries
clos69, I dont recall if it was push or pull I will look and get back to you. I had it on my 69 that had a 366 big block in it. i parted out the truck and dont need it any more it works fine i hooked it to a battery and tested it. darkhorse970, once i have answered clos69's questions i would like to give him 24 hours to respond weather or not he wants it. Then its yours if you still want it. (this is how i have seen it done in other threads if it does not follow board rules let me know)
Thanks for the quick response...Do you have the wiring harness for it and can you please check shipping to Tx,76182, thanks Carlos
someday
Carlos, shipping will be $18 Also i looked quick before i left for work the fan is a pusher and i do not have the wiring harness. thanks, jason
Jason, thx for the info but I'll pass it on to the next person in line.
someday
darkhorse970, Your up on the fan shipping is $18. Its yours if you want it.
![]() Join Date: Nov 2002
I'll take the Holley. I'll PM you for payment details.
