07-14-2010, 09:37 PM | #1 |
72 C20 trailing arms
I've got a 72 C20 that the only thing keeping off the highway is the rotted rear trailing arms. Any info on where to find a set would be appreciated greatly!
07-14-2010, 09:39 PM | #2 |
Re: 72 C20 trailing arms
lmc or other vendors would probably have them but if you are posting a "want to buy" ad you need to be a site supporter.
-Scott- |
07-14-2010, 11:16 PM | #3 |
Don't limit yourself to strictly C20 truck (trailing) arms. The C10 arms are the same thing w/some reinforcement plating. ECE sells a reinforcement kit if you can find some C10 arms (C10 arms will work as is but would be better if reinforced).
ECE (early classic enterprises), CPP (classic performance products), & Porterbuilt Streetrods all sell better than original aftermarket truck arms that will work will coil springs. LMC offers 'Made in China' replacements....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-14-2010 at 11:17 PM. |
07-15-2010, 10:09 PM | #4 |
Thanks for the info SCOTI, I'm going to check them out.
07-15-2010, 11:13 PM | #5 |
Glad to help.
07-16-2010, 12:05 AM | #6 |
Damn SCOTI, just checked out your garage and I'm a little bit jealous!
07-16-2010, 12:10 PM | #7 |
i have a set of roush arms in the for sale section. need to trim a couple brackets off and they will bolt in.
07-16-2010, 06:43 PM | #8 |
if what SCOTI said is true then i saw replacment trailing arms in the classic parts catalog for 1/2 ton @ $449 a pair
Mark 1968 C-10 SWB 307/munci 4spd/411possi 1986-1990 1972 Cheyenne-10 LWB 350/TH350 IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER U. S. Navy Seabee "CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard" |
07-16-2010, 08:46 PM | #9 |
They're good..... Porterbuilt's are better. Stronger & less deflection w/more articulation. It's like someone sat down & thought "how can I build the ULTIMATE truck arm".
07-17-2010, 08:40 AM | #10 |
Oh man, When I first bought my trailing arms from lmc maybe seven years ago they were U.S.A made, never would of got them if made else where. At that time I don't recall trailing arms being made anywhere. At least they were made of good quality when I did get them at that time can't speak for now . I now notice a lower price and that there's no mention of being U.S.A. made. Bummer! But I do agree with Scoti. Don't limit yourself and there are other venders
07-17-2010, 10:11 AM | #11 |
NGN you did it. You got me on my tangent. Sorry in advance. I don't think hardly anything we buy now is made in the US. Even if it is a US product most of the parts are made somwhere else. Then they still put made in the USA on it. I think that a US based company that outsorces parts or all of it's product should get the sh)@ taxed out of it for import tax maybee then they will bring some of the work and WORKMANSHIP back in the states. Sorry I went on a tangent and hijacked the tread this stuff just anoys the heck out of me
08-10-2010, 06:10 PM | #12 |
I have a pretty clean pair of c20 trailing arms i just pulled off of a 68 c20. I think they are the same. Anyway this truck spent its life in arizona and ended up here to get parted so they are much nicer than any I have found in the midwest. If you are interested call me 217-791-2883
Friends don't let friends drive fords. |
08-10-2010, 08:08 PM | #13 |
I bought my 72 c20 and within a week they broke but I posted an ad on craigslist and in about two weeks I found a decent set for $60 only thing is they are for a half ton but Ill fix that
08-10-2010, 08:43 PM | #14 |
Short and long beds the same length arms right?
08-10-2010, 09:13 PM | #15 |
Yes.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-10-2010, 11:58 PM | #16 |
go look in a salvage yard I just pulled a set off of a '72 c10 for my '69 c20 and Im just going to reinforce them. I got mine for $40 bucks and they look great. the only issue I have run into is getting the old ones off. mine broke as well after a week of owning it. everything is rusted together so I have been doing alot of cutting today. still not even close to being done. I wish there was an easier way. good luck with yours.
1969 C20 3/4 ΜΟΛΩΝ ΛΑΒΕ |
08-11-2010, 06:09 PM | #17 | |
08-11-2010, 07:20 PM | #18 |
well I solved my issue. I went the lazy route and am currently having a shop do it. To frustrating for me at this time. have to pack up to move Friday. good luck with your adventure guys.
