![]() Join Date: Nov 2009
The brake "idiot" light is on, what turns this on? fluid level is fine, brakes work fine, e-brake is released.... what gives?
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
I'm a poor spectator
Re: Why is my Brake light on?
Mine would come on when I slammed the brakes and stay on for awhile, no idea why. Just a thought.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 07-14-2010 at 11:01 PM. |
Future TOTM Winner
That light has nothing to do with the Ebrakes in these years. Unfortunatly it only tells if you are having proportioning valve problems. Basically if the front and back system are "out of whack" that light will come on. If the proportioning piston travels too far one way or the other it will activate this switch. Usually it means you have a leak somewhere or a bad caliper/wheel cylinder. It's also possible the switch is just stuck or you have a crossed wire which could be your issue beings the brakes seem to be working fine. See this diagram...there should be a tan wire plugged on to the switch terminal.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 07-14-2010 at 11:06 PM. |
Thanks Critter!
this gives me a place to start troubleshooting....
Future TOTM Winner
No problem, my Blazer did the same thing (brake system was fine otherwise) I removed the switch and found that it was gummed up and stuck. By the way, the switch isn't in fluid, it is in a dry cavity, or at least mine was, so its easy to unscrew and reinstall.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
critter is right. The end of the switch sets in an indent in the piston, and if it touches the piston it turns on your brake light. But the switch is made of nylon, and if you really crank down on it (too much torque) it will also make contact, and your light will be on, even though their's no problem with the brakes. Make sure your master cyl. is full, and pump your brakes pretty hard a few times, they'll usually go out.
