Water pump to intake hose?
How did you do yours?
Or,can I do away with mine? Right now it looks stupid with a hose looping up and over to the intake fitting. It's a 68,C-10 with a 327. Thanks, Mike. ![]() |
Future TOTM Winner
Re: Water pump to intake hose?
You could always reconnect the heater core and make it look like its supposed to...and your heater would work.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 07-14-2010 at 11:45 PM. |
Chevy Lover Till The End.
Look in your brass fittings drawer if you have one and get two plugs out, thread seal them, remove the old hose & fittings and screw in the plugs, tighten them up & your done.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
