Old 07-15-2010, 11:50 AM   #1
DjS71
Post Power Brake converison '71
So, I thought I had dotted all my Ts and I CERTAINLY crossed my Is... Got a used setup off a 72 booster + bracket + mc + pedal rod.
That pedal rod seems too short. I know I've seen a thread that had someone using a female hex -> male threaded stud extension on that rod but i can't find it through search for the life of me.... (If you guys find it OR know off hand what the thread size is I can pick one up @ work)
I had it all hooked up and the brake pedal was noticeably lower than both gas and clutch pedals. Also, at rest it drags the linkage so that its touching the firewall, and i don't think that is the way its supposed to be.
(307, 3-on-the-tree)
One more question, on the back of the booster itself, there is a boot that covers a plastic cylinder that surrounds the push rod. The boot is well.... old and busted, and i can see a crack in the plastic cylinder. Do I need a new brake booster?
Thanks in advance.
~Dan
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 07-15-2010, 02:37 PM   #2
hddavis
Re: Power Brake converison '71
i have been looking for the same thread for a week now. i believe it had pics of rod also but i can not find it. if some one has the length maybe i can make one a pic would help to
hddavis is offline   Reply With Quote
Old 07-15-2010, 03:16 PM   #3
RichardJ
Here is a picture that teeitup posted from a '71 that he is parting out.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-15-2010, 05:38 PM   #4
DjS71
Doesn't do too much for us, but thanks for the pic. (Actually it helps on the other bracketry, thanks!)
Though... my booster isn't as round....
Maybe I'll go snag a couple different lengths from the hardware store and see what i come up with.
Until then, hopefully someone can dig up that fossilized thread for the both of us.
Old 07-15-2010, 07:27 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
thats funny I bought a booster from him and it was bad I have been waiting for him to get another??
anyway As far as the rod goes you need to use the one with the booster not your old one I ran into the same issue..also make sure you check your brake light switch for adjustment when your done....
there is no real check for a booster.....its hit or miss its nothing but a big rubber diafram if it leaks then your brakes will be hard..they will still work but very hard..
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 07-16-2010, 02:09 AM   #6
hddavis
any idea of a company that sells the pedal to booster rod?
Old 07-16-2010, 03:26 AM   #7
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I did this upgrade to my truck 72chevy and well you have to use the new rod that came from the power brakes set up because the rod on the non power set up doesn't work, and it should all bolt right up with no problem.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-16-2010, 07:30 AM   #8
Hottrucks
Hottrucks's Avatar
who ever you bought the set up from???? or your going to have find used...I'm not sure if any of the new models fit??
Old 07-16-2010, 08:08 AM   #9
Tynee
I miss this truck.
Tynee's Avatar
If I remember correctly from converting mine, nobody reproduces this part. Used is your only option. I got lucky and a local member, Huck, found one at a salvage yard for me a couple days after I posted a WTB on here.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 07-16-2010, 09:38 AM   #10
DjS71
I used the one that came with the used setup i bought, perhaps i was given the wrong one... hmm....
In regards to my other question, I'll take a pic when i get home, if the little woman doesn't have me running in circles again...
Old 07-16-2010, 10:31 AM   #11
Tynee
I miss this truck.
Tynee's Avatar
As far as I remember, the only difference between the power and the manual pushrods, is the eye on one end to attached to the pivot that applies pressure to the Booster pushrod. The length SHOULD be adjustable. Can you lengthen the rod enough to get your pedal to a functional height?
Old 07-17-2010, 07:40 PM   #12
DjS71
It's 7/16-20 Thread, which apparently has been forsaken by most hardware stores...
My other issue
Does this = new booster time?
~Dan
Old 07-17-2010, 10:05 PM   #13
sept987
This might help probably not, but I got one off a 79 pickup, and installed it. I needed to make the rod 2 inches longer, and never have had a problem.
sept987 is offline   Reply With Quote
Old 07-18-2010, 08:27 AM   #14
Zeke
Active Member
Here's a link where you can get 7/16-20 threaded rod, they also have it in stainless for more$
http://www.use-enco.com/CGI/INPDFF?PMPAGE=780&PMCTLG=00 oil finish low carbon steel
http://www.use-enco.com/CGI/INPDFF?PMPAGE=778&PMCTLG=00 stainless
and 7/16-20 coupling nut
http://www.boltdepot.com/product.aspx?cc=7&cs=181&cm=6
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 07-19-2010, 09:53 PM   #15
DjS71
Alright, I had one of the guys @ work weld a nut to the back of a 7/16-20 bolt, little redneck, but cheap & easy. Now, @ rest against the pedal stop (plate bolted to underside of dash) i can get the pin in & out, is this where its supposed to sit with no outside pressures on it? Can anyone snap a quick pic of an in-use pb on their trucks?
and heres the pic for my last question: Does this mean i need a new booster?
Old 07-20-2010, 07:42 AM   #16
Tynee
I miss this truck.
Tynee's Avatar
Sorry, I don't have a pic handy, but it sounds like you've got it where you need it. Do you have any free play before you start to feel the brakes engage (I guess that's kinda hard to judge with the booster laying on the ground in pieces).
Now tighten everything down, and see if your brake lights go out. If not, you'll need to adjust the brake light switch down to the pedal. And just because they are out now, doesn't mean they are going to go out when you press the pedal and let it return naturally. I went through a period after I installed mine where I had to pull up with my toe to get the lights to go out, until I got a chance to get back under the dash and adjust that switch.
I think so, but I'm no expert.
Old 07-20-2010, 07:54 AM   #17
Hottrucks
Hottrucks's Avatar
heres what mine looked like before the install you can see what the rod looks like...like I said before I'm looking for another booster.. put that one in and see if it works ?? if so great if not then lok for another and you'll have to deal with the hard pedal till you swap it
Old 07-20-2010, 11:27 AM   #18
RichardJ
djs71, that booster is from a van.
Old 07-20-2010, 11:43 AM   #19
DjS71
Mine or Hottrucks? Also, does that make things difficult?
EDIT: Clever editing skills, RichardJ.
Old 07-20-2010, 07:15 PM   #20
Hottrucks
Hottrucks's Avatar
that maybe why your peddle rod is funky??? Mine came from a PU I think like I said it came from a board memeber
Old 07-20-2010, 08:51 PM   #21
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no one has mentioned that you have to install the pushrod on the other hole in the pedal arm.
Old 07-23-2010, 10:43 AM   #22
DjS71
There is only one free hole in my pedal arm. (2 technically but the upper one is the pivot point)
I'll bolt it all back up and break out the vacuum pump and see what happens with the booster.
Old 07-24-2010, 05:13 PM   #23
DjS71
Put Vacuum to 'er and No dice.
Whilst I ponder what to do with that, I tried to get the pipe plug out of the manifold behind the carb so that when I get a new one, the vacuum line is already run. Stuck solid.
While I'm in there I look down at the alternator bracket and see a whole mess of washers behind it. I assume this isn't standard operating procedure?
Bring on the snowball.
