Old 07-15-2010, 09:32 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
6.0 LS2 LQ4 in my 72 GMC Super Coustom 1500
I'm so glad we finally have this subforum!!! I will be starting the LS2 swap into my 72 GMC with 200 4R trans. Can't wait to get started. Just trying to round up the parts I need. I have a 01 6.0 that's not DBW. It's still shrinkwrapped on the pallet. I also have ECE motor mounts and still havent decided on headers yet. I want cruise control though, so I need to figure that 1 out. I cant type well I have a cast on my right hand.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-15-2010, 11:41 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 6.0 LS2 LQ4 in my 72 GMC Super Coustom 1500
I'm running a newer 6.0 but am also going with a 200-4r. Mine will be carb'd tho...not efi.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-18-2010, 04:51 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Just FYI - if your 6.0 is a 2001 it's an LQ4, not an LS2. The LQ4 is a Gen III truck engine, and the LS2 came out in 2004 or 2005 in the Vettes and GTO's and is considered a Gen IV.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-01-2010, 11:01 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Here it is. Finally started working on it. Hope to have it installed within a few weeks. I have already ordered the new oil pan 19212593 and DT 324y-c headers.
Old 08-03-2010, 12:07 AM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
More progress. Now I plan on selling my 200 4r that's currently in my truck and buying a 4L65. I have a 2 piece driveshaft will I have to get a new driveshaft made, and will it have to be 2 piece? Maybe just get the front yoke to fit in the 4L65 welded to my current driveshaft. What to use to adapt my current throttle cable to the cable on the 6.0 LQ4?
Old 08-03-2010, 09:30 AM   #6
glock35ipsc
Use a throttle cable from a 99-02 6.0l.
Bob
Old 08-03-2010, 01:05 PM   #7
68GMCCustom
Why sell the 200-4r for a 4L65e? For computer control?
IMHO the gear ratios(1-2, and 4th) are better on the 200-4r, it can be built to handle as much hp as the 4L65e, and it'll respond quicker to manual shifts with the mechanical shift system. This is something the computer control transmissions...with a electronic shift system just don't seem to do well...even with a tune.
Kurt -
Old 08-03-2010, 01:25 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yes, for computer control, one complete system. I have played with the 200 4r for a long time and still cant get it to shift how I like it. I have the bowtie overdrives bracket and cam adjuster and still not happy with it. I have checked all line pressures and they are fine. It might have been the old 355 motor or maybe the 3.07 rear gear. I have a B&M Shiftplus on my 96 Z71 with 4L60 and like it, so maybe a good tune with it behind the new 6.0 will be better.
Old 08-08-2010, 01:07 AM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Update, Installed last night, waiting on harness from Speartech, new 4L65 trans, fuel pump, adapters and fittings, and headers. The second pic is the fan clearance using ECE mounts. I think I might be able to use the LS fan and original truck shroud. There is 1 1/8" clearance between the rad. and fan.
Old 08-08-2010, 01:11 AM   #10
68GMCCustom
can you take a shot that shows how much space there is between the motor and the firewall for me? I've got the ECE setup and now I'm thinking I might want to kick mine back an inch or so.
Kurt -
Old 08-08-2010, 01:29 AM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Almost 3" I was considering moving mine back too by using the rear most upper holes in the frame but then I wouldnt be able to use 1 of the bottom mounting holes. The 200 4r that is currently still in the truck is about 1 1/2" from mounting to the block. So it might be coming back out.
Old 08-19-2010, 11:28 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
More progress. It has a 4L 65 behind it now. Button up some wiring, fuel fittings, fill fluids, install Lokar shifter, install shortened driveshaft, drill new trans. crossmember holes and fire. Hopefully Saturday afternoon.
Old 08-20-2010, 06:41 AM   #13
Juiced06GTO
Sick! Looking good man!
Juiced06GTO is offline   Reply With Quote
Old 08-20-2010, 10:54 AM   #14
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I thought I would share something with you guys. I got this over a year ago. This is who I am.
Old 08-22-2010, 02:18 PM   #15
jb1016
"Oh well, it's a driver."
jb1016's Avatar
That's love right there! Great swap man.
Old 08-22-2010, 09:13 PM   #16
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Making progress with my 6.0 LQ4 and 4L65 swap. Just a little bit of wiring and plumbing left.
Old 08-22-2010, 10:25 PM   #17
68GMCCustom
can you get a side shot that shows the mounts, and where in relation to the frame (mount holes or whatever) the motor is?
Kurt -
Old 08-22-2010, 10:46 PM   #18
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Here's a side pic. What are you guys using for spark plug wires? I don't like the MSD wires I currently have that Doug Thorley recommended. And the Lokar ed-5008 dipstick tube I had to mount on the frame rail, because it wouldn't fit up thru the header and mount to the head or header flange, and Doug Thorley says to use it.
Old 08-22-2010, 11:24 PM   #19
68GMCCustom
I'm thinking my motor needs to come back like 2.5"-3"?
Kurt -
Old 08-23-2010, 12:51 AM   #20
eagleuh1
eagleuh1's Avatar
I rebent my stock dipstick tube to fit and rewelded the bracket on where it would bolt to head.
Are those MSD wires with the bendable multi angle plug ends. Thats what I used and liked them.
eagleuh1 is offline   Reply With Quote
Old 08-23-2010, 12:53 AM   #21
eagleuh1
eagleuh1's Avatar
Sorry, I fabbed up a bracket to bolt to the head and welded it to the rebent dipstick tube. I'm cheap.
Old 08-29-2010, 10:56 PM   #22
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Here's a link to a video of mine running with open headers, shortly after getting it running. I know there's no air filter on it.
Old 08-29-2010, 11:49 PM   #23
68GMCCustom
Hey congrats! Sounds mean...but tame.
So which plates did you wind up using?
Kurt -
Old 08-30-2010, 10:49 AM   #24
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I used the TPI parts plates. They are thick and strong and well made and powdercoated. I just had to slot the engine stands and frame a little to get it to set down in there in order to line up the 2 single bolts into mount.
Old 08-30-2010, 10:50 AM   #25
eagleuh1
eagleuh1's Avatar
Chevydog66, What intake tube is that your running. Looks good. What does it cost also? THanks. Trucks looking good.
