nitrous question for a buddy of mine
i am asking this question for a buddy of mine who wants to runner a smaller shot of nitrous.
he has a 350 bored .30 over, with and eagle street/ strip rotating assembly, the crank is cast steel, keith black pistons, aluminum heads, 200cc with 2.02/ 1.60 valves with bronze guides, comp extreme energy .507/.510 cam flat tappet, roller rockers, edlbrock super victor, with a 670 holley carb. it is a freshly rebuilt engine with 0 miles at the moment. he wants to know how much nitrous can this motor handle. thanks david |
On a budget like Fred Sanford
Re: nitrous question for a buddy of mine
Forged or cast pistons? Ring gap? I personally wouldn't spray more than 150 on a cast crank even with good pistons/rods/rings. If it's got cast pistons and tight ring gaps, she won't handle much if you want it to last very long.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
i think he sed there hyperpurectic or however you spell that
If so, then special attention needs paid to the ring gaps. If you gap them to n/a specs and spray it, you're gonna lift ring lands quick. With proper ring gaps, I'd spray up to 125 (properly tuned) on that motor.
I agree 100%.Problem is common motor was built then the nitrous idea hit. Its always better when you build it to be run with nitrous. personaly I always build my personal motors like they are inteded to be run with nitrous.This way Im safer and with me I know theres always a chance.
Tell your buddy hes better off keeping it at 100 hp or less shot IMO. |
#7 | |
![]() Join Date: Jan 2010
cast crank and hyper pistons will take 100hp.
if you go to 150hp you need to make sure to pull 6-8 degrees of timing and make sure the fuel supply is adequate. those pistons don't take alot of heat. that said. i've been spraying a 150 shot to my LT1 roadmaster wagon for several years and it comes with hypereutectic pistons. |
He best 100% be sure the ring gaps are correct on those keith black pistons or he will be sweeping parts up. Do a google search about Keith black pistons. They are super sensitive to proper ring gap. I would have personally used a different piston but hes got what hes got already.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#10 | |
mini truck racer
For your buddies motor i would put a sniper 100-150 or powershot 125 kit on it . They have fixed jet sizes and all he has to do it maintain bottle pressure , ensure proper timing and fuel pressure . Also the motor needs some miles on it . The more breakin miles the wider the ring gap will get . Without knowing the ring gap , i would for sure do a good break in and not spray it til it had say 3-5000 miles on it .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 07-21-2010 at 07:25 AM. |
#11 | |
