Looking for a media blaster in the south central PA / northern Maryland area
I’m trying to find a media blaster in the south central PA / northern Maryland area, I’ve found a place that will sandblast but I need the hood and side panels stripped and I’m concerned that sandblasting will warp them. I’ve also read that soda blasting may cause problems with some paints so I’m looking for a shop that uses a soft media like walnut shells.
Thanks |
Re: Looking for a media blaster in the south central PA / northern Maryland area
I had everything on my truck sandblasted and had no issues. The guy i used
would not blast the flat areas of the hood and some other areas that had no real support (Flat areas on the fleetside, Parts of the outer door ect..). For those areas i used a angle grinder with a clean and strip disc and a DA. I searched around and could only find soda and sandblasters around me and i am about 45 min from York. |
