Old 07-16-2010, 11:32 AM   #1
watindes
watindes's Avatar
Cool Should I drop it or leave it as-is?
Should I drop the rear or leave a rake, keep or leave says it all! The top pic is before I removed the helper spring after that it it dropped the rear about an inch the next two are after.
Thank you for all the comments!
Jesse
The ultimate swear!
Your mother is a *beep beep beep*ing*beep*lorem ipsum*beep beep beep*admiumvenium*beep beep beep beep*turolagulio*beep beep beep beep beep beep beep beep* hippopotamus*beep beep beep beep beep beep*beep beep beep* Daniel Radcliffe *beep beep beep beep* with a bucket of *beep beep beep beep* in a castle far away where no one can hear you *beep beep beep beep beep beep* soup *beep beep beep* with a bucket of *beep beep* Mickey Mouse *beep beep* with a stick of dinomite *beeeeeepppp* magical *beep beep beep beep* ALAKAZAM!
watindes is offline   Reply With Quote
Old 07-16-2010, 11:43 AM   #2
baclay9
Re: Should I drop it or leave it as-is?
I personally would drop the back another 2" or so
baclay9 is offline   Reply With Quote
Old 07-16-2010, 01:30 PM   #3
Sooner84
Sooner84's Avatar
I'd drop the back a little more
1984 chevy swb(1st truck, sold..)
2001 RCSB silverado, 5.3 with a little extra
2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s
My first (1984 c10) Build
Sooner84 is offline   Reply With Quote
Old 07-16-2010, 01:38 PM   #4
XtremeBowtie
XtremeBowtie's Avatar
I say Drop it. You probably couldn't care less, but I've never been much into the "raked" look.
Btw, what size wheels and tires are those?
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
XtremeBowtie is offline   Reply With Quote
Old 07-16-2010, 01:44 PM   #5
79gmcclassic
79gmcclassic's Avatar
drop the front 1 more inch then go 2 in the back to have the perfectt rake! nice smoothies too!
79gmcclassic is offline   Reply With Quote
Old 07-16-2010, 01:50 PM   #6
MotorHead Lon
MotorHead Lon's Avatar
I'd say about a 5/5 drop. And keep the smoothies. Lowering spindles and a coil cut from the stock coils up front and axle flip in back.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 07-16-2010, 02:08 PM   #7
Acrophobia
Acrophobia's Avatar
I vote to drop it. Lowered a little more with those wheels will look sweet!
Acrophobia is offline   Reply With Quote
Old 07-16-2010, 03:31 PM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Drop it but keep a small rake. These trucks look great with a rake!
Our truck look best with the wheel up near the fender lip.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-16-2010, 03:33 PM   #9
Adams74Chevy
Adams74Chevy's Avatar
+1
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 07-16-2010, 03:49 PM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Absolutely! If they are level, the front always looks higher since the wheel well opening is almost 2" higher in the front than the rear.
Dropped to the point where both front and rear tires have the same distance to the top of the wheel well lip gives them almost 2" of rake. Perfect! My ideal height is the top of the tire even height-wise to the lip.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-16-2010, 04:08 PM   #11
Davidmichael
Davidmichael's Avatar
drop it a bit.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 07-16-2010, 04:41 PM   #12
ERBSIX
ERBSIX's Avatar
Rake. Always and forever rake.
* steps back preparing his Rake to fight off the air-baggers
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 07-16-2010, 04:54 PM   #13
big10ratrod77
big10ratrod77's Avatar
leave it the way it is in the bottom picture stuff then stuff sum huge tires under there it would be so bad
maby somthin like this? http://www.summitracing.com/parts/COK-72150/
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 07-17-2010, 01:50 AM   #14
iroc12valve
I say lower the back another little bit
Could you take another leaf out ? keep in mind you need at least three on each side, the main one that bolts to the hangers, and 2 more
the only time i like a rake is when im gardening lol
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
