Old 07-16-2010, 07:00 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Nother Q. Step sill protectors?
I cant find anything that I can apply to my step sills to protect the paint, i dont want it to get scratched and nicked from people getting in and out. but I want something that i can take off and change as needed and it not leave a sticky mess on the paint either.
Any ideas?
Thanks!!
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 07-16-2010, 08:43 PM   #2
Sammy
Re: Nother Q. Step sill protectors?
Try a small piece of 3M double stick Dbl sided molding tape two small pieces an inch long would hold it real secure. Available at a good paint dealer. Just a little bit of that stuff on a clean surface works wonders. Other than that your talking screws which I know is not what your interested in.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-16-2010, 09:24 PM   #3
hayhauler71
hayhauler71's Avatar
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=85
This might be what your looking for.
hayhauler71 is offline   Reply With Quote
Old 07-16-2010, 09:56 PM   #4
gkesseru
gkesseru's Avatar
How about a flexible magnetic sheet?
Paint it with Vinyl paint or cover with thin sheet metal?
http://www.magnet4less.com/index.php?cPath=4_18
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 07-16-2010, 09:57 PM   #5
71swb4x4
71swb4x4's Avatar
On my cargo van I took it to a sign shop and had them apply clear vinyl over the paint. It has held up well so far.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-16-2010, 10:17 PM   #6
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
x2 on a magnetic strip you could take off at shows.
Or for something more permanent, get some skateboard grip tape. I think they make some transparent, too.
Or just make everyone go barefoot...
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 07-16-2010, 11:25 PM   #7
78bronzechariot
78bronzechariot's Avatar
Griot's Garage sells protective film that can be removed and replaced.
http://www.griotsgarage.com/product/...rrivals&page=1
78bronzechariot is offline   Reply With Quote
Old 07-17-2010, 08:11 AM   #8
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Thanks again yall, I think LMC is the closest thing to what Im looking for out of the suggestions, Will be next week before I can order anything, keep the suggestions comming.
Thanks so much
junk
Old 07-17-2010, 01:31 PM   #9
AirSpeed
AirSpeed's Avatar
I looked for the same kind of solution on my 69, I finally just applied some 2" wide grip tape there and left it, I figured anything I put over the sill is going to eventually scratch the paint so I may as well put something there that won't scratch (itself) and looks decent. It's been there for ten years and still looks new.
AirSpeed is offline   Reply With Quote
Old 07-17-2010, 07:44 PM   #10
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
That makes sense too. Was it clear?
Old 07-18-2010, 01:03 AM   #11
AirSpeed
AirSpeed's Avatar
No, I used some black 3M grip tape, I have seen the clear stuff on other items and it looked kinda ugly after awhile, I don't know if the clear I saw was of any quality, it may have been some cheap stuff but it showed the dirt pretty fast and looked kinda cloudy. If you do use grip tape get some good stuff and clean the area with alcohol before putting it on, it makes it very permanent. Make sure it's where you want it also, once you apply the 3M grip tape it's there for good!
Old 07-18-2010, 09:18 AM   #12
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Thanks!!
