Old 07-16-2010, 07:03 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Gas gauge Question
Ok, my truck hasnt really been run much in the past couple a years, and she hasnt had a lot of gas in her at any one time either. I filled the tank when I brought it home last week, today after I should be atlease a quarter tank low, it says I have a tank and a HALF, lol. What would make my gauge go so far to the right and how do I go about fixing it?
thanks again!!
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 07-16-2010, 08:36 PM   #2
Sammy
Re: Gas gauge Question
More than likely and the easiest fix is to trace the wire from the tank to the fuse box. Usually it gets a break in the wire when it runs under that sill plate on the drivers and grounds out. If you disconnect the connection on the tank the gage should go past full with the key on. If that doesn't fix your problem then your looking at a possible ground loss at the tank or on your dash gage. The next step is checking the float requiring removal of the seat for access and checking for correct OHMS. If you do a search, there are some threads to point you in the right direction with pics. Good luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
