07-17-2010, 12:42 AM | #1 |
Need brake help
I have a 51 chevy truck with MII front suspension with 11" disc brakes, firewall mounted booster a prop. valve on the frame and rear drum brakes with multiple front brake problems
1 The front outside brake pads wore down to metal after about 500 miles 2 The inside pads were about 50% except the top edge was above the rotor 3 There are wear marks on the top caliper bolts wher the rotors have rubbed 4 I have a squealing sound from the front every time I turn a corner |
07-17-2010, 12:51 AM | #2 |
gets board easy.......
Re: Need brake help
sounds like a loose or incorrect wheel bearing or a bad/ wrong caliper,
only on one side correct? |
07-18-2010, 01:48 PM | #3 |
Re: Need brake help
Both sides are exactly the same.
How tight should the wheel bearings be ? |
