help with air conditioning
Need to know how to disconnect the left line on this Air conditioning dryer.
It has the spring seal and I do not know how to get it off. Any help?????
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe. John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me. My Book "Why Cancer is Not Bad Luck" by WestBow press |
"the other guy"
Re: hekp with air conditioning
there's a "special" spring seal tool. you can rent it at autozone or just buy on if you do this often. simple to use
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
I had the air to about 68 degrees or so coming out the vents and put more Freon in. Now it is not cooling like it was can I have too much Freon in the unit??
Everything is working ok it seems but not cooling now.
"the other guy"
yup, excessive refrigerant can cause no cooling.
