![]() Join Date: Jul 2010
Where do the three AC cables go?
I am installing the cables to the stock AC controller on a 71 but I am not sure which one goes where. I have one cable attached outside the firewall to the plenum but not sure where it and the others attach to the controller with three arms...defrost...outside... Any help would be appreciated!
Thanks, BTM Last edited by BlackTopMotors; 01-10-2011 at 01:57 AM. |
Re: Where do the three AC cables go?
Here are some pics.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I'll need that diagram myself here in a couple weeks!
Thanks Jim. Mike. |
![]() Join Date: May 2010
The cable outside the firewall to the plenum attaches to the bottom of the control head, The outlet selector cable attaches to the middle control arm and the defroster cable attaches on the top of the control arm. Here is a picture from the service manual. Hope this helps. |
Thanks!!! I need to get a service manual, I am trying to go by general knowledge...but it's like reinventing the wheel. Thanks all, you guys know your stuff!!!
Roger |
Well, I got them in/attached but it was a bit more difficult than I expected. I couldn't get the defrost cable to move freely and after working it a bit I ended up breaking the portion where the loop tip attaches. I had a spare controller and redid the whole thing and even used a spare cable but it's still too stiff/ not as smooth as the others. Anyone have ideas? They would be appreciated. I am not happy using the spare controller/it wasn't in as good of shape...I tried to save the best portions...do the best with what I had but man, it was just one of those days where you put in loads of effort and gain little.
Roger Last edited by BlackTopMotors; 07-19-2010 at 09:43 PM. |
![]() Join Date: Oct 2009
Are you using the correct cable for the defroster? The longest one, obviously, goes through the firewall to the temperature door, the shortest one goes to the duct selector box, and the middle-length one goes to the heater/defroster selector. From my own experience you can put these last two in the wrong place and they will work, but then the defroster is very stiff.
1971 C10 Longbed, 350/TH350 |
#8 | |
I need this
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
Subscribed! (For later reference.)
![]() ![]() It ain't yours, if you didn't build it! |
#11 | |
Source: comparing the OE cables that came on the truck. The one going through the firewall doesn’t have a fastener clip on the end that connects to the box on the outside firewall Tip save and transfer over the end clips off of your old cables when using repro cables. As usual with repro stuff the clips that come with them don’t fit properly
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
