07-17-2010, 03:11 PM | #1 |
dual master, rear end, and spring questions
Hey Guys
Just got a 65 GMC short/step. All stock. Im gonna end up beefing it up alittle. I have a few questions. Its got manual drums all around. I wanna put a dual master on it. What do i need? Its got a 10 bolt rear. I wanna beef that up, or swap it. I also want posi. Any ideas? I also wanna lower the front alittle. 2" or so. Whats the difference between doing drop springs, or drop spindles? Josh |
07-17-2010, 05:43 PM | #2 |
Re: dual master, rear end, and spring questions
If you have a GMC with leaf springs your "10 bolt" rear is most likely a Dana 44 unless it has a round cover. For an upgrade keeping the 6 lug pattern, you could go to a 12 bolt off a 4WD Chevy (not GMC), but there won't be a huge increase in strength over the Dana. The next step up would be a 14 bolt semi-floating from an 88-98 light duty 3/4 ton. This will be a couple of inches wider than your stock rear, but totally doable if you order your wheels with appropriate backspacing. Stock (5.5" or so) wheels will usually work as-is.
All else being equal, I like drop spindles better than springs because you won't lose any suspension travel. For your dual MC and booster you can use a 67-70, as these still had drums all around. However, if you get drop spindles you will need to convert to discs. I don't believe anyone is making drum drop spindles any more. Ray |
07-17-2010, 10:58 PM | #3 |
60-66 Nut
Ray is pretty much spot on. Although the GMC 4x4's did have the 12 bolts from 1963 to 1980 as well as the 8.5 10 bolts after about 1980-81. I would suggest trying to find one from a 1976 or newer since they had a little bigger brakes.
If you plan on staying with 4 wheel drums, the '67-'70 master cylinder will work for you. If you convert to discs up front then a '71-'98 master cylinder will work....with a brake booster. The '71-'75's were available with manual brakes.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-17-2010 at 10:59 PM. |
07-19-2010, 08:49 AM | #4 |
Im just gonna leave the drums. Ill get one of the 67-70 Masters.
Has anyone used a Powertrax in one of these stock rears? Any other rear end options? |
07-19-2010, 12:46 PM | #5 |
For street driving I like the TrueTrac. It is smooth, noiseless, and doesn't require special lube. One to stay away from is the Gov-lock. Engagement can be violent and unpredictable.
Ray Last edited by raycow; 07-19-2010 at 12:48 PM. |
