Old 07-17-2010, 04:26 PM   #1
kcfirstbuild
drum/parking brake cable help ! ???
I took to much off now i can remember if im putting my drums and parking brake cable back together the right way. I took the whole drum assembly off the axle so i could clean and rebuild them on a bench,but did not remember which one was right or left.
If anyone has a photo of what the back side of the rear drums look like on a 1967-68 c-10 it would be helpful.
The one thing im really confused about is that the parking brake cable hole is facing the rear of the vehicle, does the cable curl under then clip to the trailing arms ?
kcfirstbuild is offline   Reply With Quote
Old 07-17-2010, 04:55 PM   #2
vectorit
What?
vectorit's Avatar
Re: drum/parking brake cable help ! ???
On mine, the E brake cable enters from the front of the axle into the backing plate.
I have a few pics of mine in my profile, even though they are 3/4 ton they are still pretty much the same.
Kinda sounds like you have your backing plates reversed, since they are Right/Left side specific.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-17-2010, 05:00 PM   #3
john
member #16
john's Avatar
This may help you.
http://www.google.com/imgres?imgurl=...BYP2tgOY6ZyQDA
john is offline   Reply With Quote
Old 07-17-2010, 05:17 PM   #4
cdowns
cdowns's Avatar
the wheel cylinder will b up top with cable pointing foreward only goes one way
Old 07-17-2010, 07:11 PM   #5
swierker
swierker's Avatar
Agreed, the e-brake cable enters at the front of the backing plate. I just finished removing the brakes off my donor rearend. Sorry no pics, the brake components were mostly rusted together anyway.
swierker is offline   Reply With Quote
Old 07-17-2010, 07:57 PM   #6
gkesseru
gkesseru's Avatar
How's this?
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 07-17-2010, 09:22 PM   #7
kcfirstbuild
Helpful, but do you have a picture of the back of that ?
I'm wondering if i put the left wheel cylinder in the right side and right in the left?
if i did would it make a difference other then the original brake lines meeting up in the same spot. I'm putting all new line in anyway.
Old 07-17-2010, 10:04 PM   #8
vectorit
What?
vectorit's Avatar
Here is mine, though it's 3/4 ton.
Driver side, then passenger side.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 07-17-2010, 11:30 PM   #9
kcfirstbuild
Will I be ok if i did mix up the left and right wheel cylinders ?
