Old 07-17-2010, 11:34 PM   #1
bigdon-70blazer
Went for a little drive.
Took the Blazer for a little drive this eve. The brakes are HORRIBLE ! I changed everything when I restored her. I rebuilt all the wheel cylinders and the master cylinder myself. Bled the brakes but at regular driving, it was like not having brakes. Any suggestions? Should I start at the master cylinder, replace it with a rebuilt one then the wheel cylinders? I changed all the brake lines also with stainless stuff from inline tube. I think I got my throttle thing worked out, actually got it up to 55 miles per hour, still got some shakedown to do.
bigdon-70blazer is offline   Reply With Quote
Old 07-17-2010, 11:36 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Went for a little drive.
I'd start by bleeding the system to make sure it doesn't have any air in the lines.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-18-2010, 08:35 AM   #3
bigdon-70blazer
Will do!
Old 07-18-2010, 10:08 AM   #4
Long Roof
Old School, New Style
Long Roof's Avatar
I would also bleed the system again. After that I would look at the MC. If its a rebuilt one I would be suspicious. I went through two bad rebuilt MC's on a vette once before using a brand new one which worked fine. Good luck.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 07-18-2010, 12:56 PM   #5
BLUE THUNDER
BLUE THUNDER's Avatar
Brake booster? It could be leaking vacuum.
BLUE THUNDER is offline   Reply With Quote
Old 07-18-2010, 02:45 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
I also would look at the master cylinder.
If you had one bad wheel cylinder or caliper it would probably be leaking or you would notice one corner of the vehicle not braking properly. Sounds like all 4 corners of yours are equally not working. So after one more good bleeding just to be sure, I would look at the MC. The booster wouldn't cause this problem, it would just cause you to lose the "power" feel, not the braking itself.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 07-18-2010, 03:50 PM   #7
72lb4x4
How does the pedal feel when you step on the brake?
Step on the brake and then start the engine. The pedal should sink a bit when the booster gets vacuum.
Does the emergency brake work right?
72lb4x4 is offline   Reply With Quote
Old 07-18-2010, 04:32 PM   #8
Jtrux
I'm a poor spectator
Jtrux's Avatar
Does it have drums on all 4 corners?
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 07-18-2010, 05:18 PM   #9
bigdon-70blazer
No power for me! It has 4 corner drums. And I rebuilt the master cylinder myself, a job I had never done but it was not that complicated so that could be the problem also. The brakes feel hard enough just not enough braking for the amount of force I seem to be giving. Boy, rebuilding a car is fun!
Old 07-18-2010, 07:48 PM   #10
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Did you "bench bleed" the master cylinder?
low'n slow is offline   Reply With Quote
Old 07-18-2010, 10:28 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
Well there's your problem! You need power disk brakes!
I'm kidding but not really. I can't remember, did you drive this blazer before the rebuild? Are you familiar with how non-power drums are supposed to feel??? I'm sure you are.
On my 68 truck with the same setup I had to spend hours adjusting the so called "self adjusters" because they weren't doing their job! Have you tried backing them out a little?
Old 07-18-2010, 11:23 PM   #12
72Levi
Active Member
72Levi's Avatar
You need to adjust the brakes more. Turn the drums by hand and completely tighten them with the adjusters, then back them off until you can actually hear the shoes with the drums. If your MC is ok, the problem is adjustment.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum
2004 FORD FX4 SuperCrew
2005 CTS-V 12 sec family car
2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it!
72Levi is offline   Reply With Quote
Old 07-19-2010, 12:03 AM   #13
Critter
Future TOTM Winner
Critter's Avatar
That's what I was getting at, I'm just a little "longer winded".
Old 07-19-2010, 08:38 AM   #14
bigdon-70blazer
I will try this...Thanks!
Old 07-19-2010, 02:08 PM   #15
cleszkie
cleszkie's Avatar
x2 on the bench bleeding of the master cylinder. I also highly recommend getting some of those "one man" brake bleeder screws for each of your brake pistons. These prevent backflow of fluid and air into the pistons as you pump the pedal. You don't need a second person to open and close the screw. Can get them in any parts store in the "Help" section for a few bucks.
cleszkie is offline   Reply With Quote
