Old 02-19-2003, 12:39 PM   #1
GreenMystChevy
will my rear end sag...
I am looking into buying a 4x4 but one of the things that I am curious about is how it will pull my boat. If it has a lift on it and I hook a ski boat onto it, will it bring the back end down so that it looks funny when towing. I know it sounds vain but I want it to look sweet when pulling the boat over the mountains, not like it is sagging in the back. What would be some ways to cure this, or are there any. Thanks guys
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 02-19-2003, 01:07 PM   #2
Mudder
Mudder's Avatar
You shouldn't have any problems with sagging but will need a drop hitch. I have a 6" for my reciever that keeps the trailer somwhat level.
Mudder is offline   Reply With Quote
Old 02-19-2003, 01:37 PM   #3
Yukon Jack
Yukon Jack's Avatar
If you do run into a little saggy butt, some air bags would do well to get your rear back where you want it when loaded down.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-19-2003, 10:52 PM   #4
Growdon
I'm with Yukon Jack. I have firestone airbags on my F#ord Powerstroke (I can't believe that I'm admitting I own a F#rd). Anyways, the airbags are great. You keep them at 5 psi during normal driving, and when you are hauling you add a little air. I haul a cabover camper, and have found that the airbags also stiffen up the rear end and cut down on sway from side to side. I plan on putting a pair on my 71 3/4 ton 4x4.
72 K5 CST 350/350. 4 wheel disks, 4" lift soft top. ###Sold
71 GMC Custom K2500, 3/4 ton 4x4. 350/350 ## Just bought, New Project
Growdon is offline   Reply With Quote
Old 02-19-2003, 11:49 PM   #5
6869704X4
Good call on pulling a boat with a 4x4. I always put mine in 4 wheel drive when putting in or taking the boat out. The front wheels on the higher part of the boat ramp which is uaually dry makes a big difference in the traction.
Another option for the saggy but is a load leveling hitch. Dont see those too often on a boat though.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 02-20-2003, 02:05 AM   #6
dtlilly
dtlilly's Avatar
4x4
Thats why I own a 4x4 in both of my trucks. If your like me, I don't get to the ramp until late, and the ramp is always slick when pulling my jet boat out. If I didn't have 4x4, I would be telling a story about how I slid back in to the water. You should be confident with your set-up, that it will pull the boat out and drive home safe. Happy boating and 4x4'ing.
dtlilly is offline   Reply With Quote
Old 02-20-2003, 12:11 PM   #7
Mike C
Mike C's Avatar
Depends on the tongue weight of your trailer. My 20' Malibu has about 400# tongue weight, but I have 3/4 ton rated springs in the Jimmy. 4x4 may be a neccessity with an automatic on the boat ramp, but granny gear and limited slip and tire spin is a non-issue, at least with my Jimmy. My pickup with the auto and Dana 60 can get stuck in a wet parking lot.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
