Old 07-18-2010, 03:17 PM   #1
LandonL
LandonL's Avatar
Inline 6 Harmonic Balancer removal??
I've got the removal tool, but I can't find a retainer nut or bolt holding the damn thing on, is there one? I don't wanna start pulling and mess anything up but I need to know. Any help quickly would be great!
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 07-18-2010, 03:38 PM   #2
Lee H
Lee H's Avatar
Re: Inline 6 Harmonic Balancer removal??
Many of these early engines came with press fit balancers the cranks were often later tapped for a bolt when rebuilt. Just check carefully before forcing it off.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-18-2010, 04:03 PM   #3
68gmsee
Active Member
68gmsee's Avatar
That's correct... My 68 only had an indentation and when I had the crank out for rework I had the machine shop drill and tap for a crank bolt. Easier to reinstall that way.
68gmsee is offline   Reply With Quote
Old 07-19-2010, 05:40 PM   #4
raycow
If your crank is threaded, don't try using the stock bolt to pull the balancer on. It's a good way to strip the threads. Instead, use a piece of allthread and screw it into the crank by hand as far as it will go. Then use a nut and washer on the allthread to pull the balancer on. It helps if you grease the threads and both sides of the washer.
Ray
raycow is offline   Reply With Quote
Old 07-19-2010, 08:42 PM   #5
qksilver
Auto zone offers the correct tool for free rental.......just make sure the threads on the tool are not messed up
qksilver is offline   Reply With Quote
