Old 07-18-2010, 06:16 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Brand new starter, shims?
hey yall!
Just before I brought my truck home, the guys put a new starter on my Burb for me. Well, its making an ungodly noise when I try to start it, and Im being told that it needs to be "shimmed" Im familiar with the concept, but have never done it. How do I know how much it needs and how do I do it?
Thanks again, and again and again!!!
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 07-18-2010, 08:32 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Re: Brand new starter, shims?
Honestly Jodie, I dunno if this will help or not
http://macc.chevelles.net/starter.htm
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-18-2010, 08:35 PM   #3
68 Stepside
huh?
Actually, from what I can gather from this pic, you need a piece of 1/8" rod (maybe a drill bit would work?) and just set the gear gap with it. I've actually never had to shim a starter or I could probably help more....
RIP El Jay
Old 07-18-2010, 08:37 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
i think there is a process, but i just do trial and error, i have had to sand down the nose where it bolts to the block to make them quiet down, instead of adding shims and sometimes you might have to just shim one bolt
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-18-2010, 09:05 PM   #5
Alex Hayley
The url that 68 stepside send will guide you. Use a 1/8" drill bit and check the gap between the ring gear and the nose shaft of the starter gear. If the gap is greater than 1/8", cut the shim in half and place one of halves between the starter and engine on the outer starter bolt. If the gap is less than 1/8", place the entire shim between the starter and engine. Repeat until the gap is 1/8".
Since you mentioned the starter was already installed, you might not have the shims. Try autoparts store...they probably will have extra shims.
Alex Hayley is offline   Reply With Quote
Old 07-18-2010, 09:09 PM   #6
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
THANK YOU!!! yalls info helps so much, i couldnt function with out yall!!
