Old 07-18-2010, 06:25 PM   #1
68jewel
On the path to financial ruin!
68jewel's Avatar
Ride Height vs Wheel Diameter
Guys, I need a little help here. Initially, I was going to go with a 22x12 rear wheel. Now, I'm leaning more toward a 20x12 or maybe 20x12.5. I don't really care about laying frame, but won't my truck to sit fairly low when it is aired out while parked. Now, I know it is possibly to do that with 22's. But, the most important reason being I am leaning towards the 20's are I want it to sit low and have a good, mean stance while at ride height and driving. It would have to sit higher with the 22's while driving as opposed to the 20's, right? What do y'all think? Am I correct in my analogy? Don't know if many have read and been following my build thread, but I will have Porterbuilts C4 front and C4 rear Dropmembers. With that being said, I want a little bit more performance out of the truck with the Corvette stuff and IRS suspension. Another reason to go with the 20's probably instead of the taller 22's.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 07-18-2010, 07:40 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Ride Height vs Wheel Diameter
Your real concern will be tire size.
The 20's will allow you to run the same height tire as a 22,... but with more sidewall.
I try to make sure the sidewall of the rear tire is the same size or bigger than the side wall of the front tires.
So,... what size front tires?
Also,... what height tires can you lay out with?
Keith
Convert to disc brakes.
Old 07-19-2010, 01:05 AM   #3
David67
David67's Avatar
IMO a slightly larger wheel in the rear would give it an aggressive stance. You could split the difference and go 22 in the rear and 20 up front.
David67 is offline   Reply With Quote
Old 07-20-2010, 11:49 AM   #4
68jewel
68jewel's Avatar
I'm not sure on the tire sizes yet if I go with 20's. Probably a 265/35/20 up front and a 315 or 325/35/20 out back. As far as laying out, I'm not experienced with it, but again, I'm not hell bent on laying rockers. I just want to get low. So, I assume I will go no lower than a 30 or 35 series side wall.
Old 07-20-2010, 01:11 PM   #5
David67
David67's Avatar
Someone gave me this site a while back. It'll help you figure out the overall height of the wheel/tire combo if need be.
http://www.miata.net/garage/tirecalc.html
Old 07-20-2010, 01:35 PM   #6
mac72
68 jewel
I'm after the exact stance your looking for.I've got 20x10 & 20x8 w/ 295/4020,245/4520 w/ thorbecke stuff front & rear. I've mocked up the bed to see how it looks.I think it's about right for me. Cant post pics from work I'll try to post some tonight.actual tire height mounted is f-28.5" / r-29"
Mac
mac72 is offline   Reply With Quote
Old 07-20-2010, 06:17 PM   #7
mac72
68, these are ride height. I Hope this helps
There is about 6" between the axle & notch
