![]() Join Date: Apr 2010
1969 K10 rear axle
I need some help. I decided to change the oil in my rear end after I finished installing my new crate motor and came across a mess. 1 outer seal is seeping, inner and outer bearing have alot of wear. The axle shafts are grooved and and need replaced. Are all 1967-1972 rear axle shafts the same? I am trying to get a shopping list together for the auto parts store tomorrow. Any information on what years are interchangeable is appreciated.
ROD ![]() 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
Re: 1969 K10 rear axle
I believe axel shafts on '67-69 are an inch shorter on each side - I know '67 and '68's are, but not 100% sure on '69.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Its confusing. Some websites show 65-69 axles are the same and other web sites show 67-81. Some say 30 5/8, 30.75 or 31 7/16. I will have to do some measuring myself I was hoping someone may have done this project and had a part number. I was going to try the U pull it yard tomorrow but they don't have any 65-69, but they have several late 70 to early 80's that I was hoping might interchange.
67-69 axles are the same length. 1970 was a change year and the axles could be the same length as the 67-69 axles or they could be the same length as the 71-72 which are 3/4" longer.
Have you considered getting some good used ones? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
The U pull it yard doesn't have any 67-69 so I am looking to rebuild it with all new parts. I am heading to the shop to measure and make some phone calls.
If it helps any, 65-66 shafts are the same length and splines as 67-69.
Ray |
6>8 Plugless........
![]() Join Date: Sep 2007
I have a 69 K10 rear axle I'm not using. I'd sell parts off of it to you if that'll work for you?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#8 | |
Ok, no problem. Good luck man, I know how it can be.
