Old 07-19-2010, 12:43 AM   #1
cstm68
cstm68's Avatar
valve cover baffles
i got a new set of vlave covers but the dont clear with the breather baffles in, are they needed or can i run without them??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 07-19-2010, 05:38 AM   #2
JimKshortstep4x4
Re: valve cover baffles
You will need baffles to keep the oil from splashing out. The covers should fit with baffles in place. I would suggest getting different covers if you cannot make them work.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-19-2010, 06:18 AM   #3
cdowns
cdowns's Avatar
have you tried turning the covers around to see if the biffles clear?
you need them for good operation and a clean motor// as a stopgap companies like mr gasket has grommets with builtin biffles ,better than nothing
Old 07-19-2010, 12:27 PM   #4
Alex Hayley
You could make your own that are more low-profile. What valve covers and baffles do you have?
Alex Hayley is offline   Reply With Quote
