Old 07-19-2010, 02:38 AM   #1
dmartin1
dmartin1's Avatar
front axel,wht axel?3/4?fill me in on this.
ok so i have a 1979 camper special 3/4 long bed 8 lug chevy 4x4 4" lift on 35" mudders.
does anyone know what the stock front axel on this truck is?(cause mines the stock axel).
it doesnt have lockers,so is that full time 4x4? whats that called?
and if this isnt a good axel to run 40's-44's on what would be a good axel?and what would be good upgrades etc?
sorry im just not very smart on the whole front axel 4x4 thing.ive read other posts but im just wayy confused.
thanks in advance guys.
best site ever,by far
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 07-19-2010, 08:14 AM   #2
b454rat
Re: front axel,wht axel?3/4?fill me in on this.
Could either be a 10 bolt or Dana 44. Get a pic, we can tell you then what it is.
it doesnt have lockers,so is that full time 4x4? whats that called? By lockers are you talking lock out hubs?? If so then it's part time 4wd.
and if this isnt a good axel to run 40's-44's on what would be a good axel?and what would be good upgrades etc? Not if you plan on wheeling it. But depends on how you wheel. I baby my stuff, I can make 1/2 stuff survive with 54" boggers, but that's just me.
Get some pics, can tell a lot more on the truck that way.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-20-2010, 09:18 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Regardless on whether it is the Heavy Duty Dana 44 or a Corporate 10 bolt, neither of those axles would be the right choice for 40-44" tires. Step up to a Dana 60 for those tires. Lots of other things you're going to need to do to be safe and able to run 40-44" tires. Start reading lots of old posts as there are many on this issue that can help guide you. Steering, brake system, lift are all going to need attention.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-20-2010, 11:39 AM   #4
Redcap
In general, the limit for a Dana 44 is around 35" tires. 37" if you keep your foot out of it and drive like an old man.
For 38"+, you will begin to break a number of things very easily. Step up to the Dana 60 if your desire is to run large tires.
Redcap is offline   Reply With Quote
Old 07-20-2010, 11:05 PM   #5
iroc12valve
My 76 is d44/14bff and its been running 39.5x15 for 8 months no problem,and believe me it sees abuse(2 broken centering pins and a set of stretched u bolts) however i dont drive it on the road. that being said it was built as a "see how it'll hold" type of thing. when i build it right I'll use 42's and a Dana 60.
it also depends on the gears mine are 4.56 and it works great, a nother guy where we weel had the same set up but with 3.08's and a 38x11 tsl he blew u joints the first time, drive shaft the second and stripped the front gears,twisted rear shaft the third/last. he went out and got 5.56's and has been fine since.
I'd take a 10 bolt with 4.56's over a d44 with 3.73 any day but i'd take a d60 with no gears even faster.
also as far as your front axle if it has 6 BOLTS and a little cap then its AWD and came with a NP 203(fulltime) but if it has little SCREWS then you've got a 4x4 with auto hubs (rare but not desirable)
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 07-22-2010, 12:47 AM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
If you buy the right parts you can run 44's on a D44. I'm not saying they are bullet proof, but I know guys that have had D44's in a pulling truck for 2 years that was pulled every weekend and had 700hp minimum running agressive 33's. LIke mentioned low gearing helps keep them alive too. Ideally a D60 is the best choice, but not everyone has great luck finding the right deal on one. I also know plenty of guys that street drive big lifted trucks with 44's and bigger. They all use moog ball joints and none of them have failed. My buddy has 49" Iroks on his 84 SWB and he drives it around 3,000 miles or more each summer. It has a D44HD and he's had no issues with ball joints. His also are HD moog ones.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
