07-19-2010, 12:26 PM | #1 |
Dana 44 ?
Will 72 model hubs, bearings, rotors (everything from the knuckle out) fit on a 74 model axle? Both front axles are dana 44's. I have heard the 74 axle runs bigger u-joints in the front shafts... anybody know if thats true?
Thanks |
07-19-2010, 06:42 PM | #2 |
Currently Blazerless
Re: Dana 44 ?
Yes the axle shafts, u-joints and stub shafts are slightly larger on the 73 up axles but your hubs, rotors and bearings will switch over with no problems.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
07-19-2010, 08:06 PM | #3 |
Re: Dana 44 ?
The axles are interchangeable. I have run 73 up axles in my 72 housing for many years. So if what you are trying to do is run the beefier axles and larger u-joints, simply install the newer shafts.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 Last edited by turp mcspray; 07-19-2010 at 08:09 PM. |
07-19-2010, 10:57 PM | #4 |
Re: Dana 44 ?
Thanks for the quick response guys, I appreciate it. Goin to pick up that 74 d44... now if only it was geared 4.10 Guess you cant have your cake and eat it too.
07-20-2010, 11:16 PM | #5 |
Re: Dana 44 ?
I got a D44 with 4.56's and a matching posi 14bolt full floater for 550 including the truck sometimes you can have your cake and eat it too
two weeks later a strap broke and the hook went flying and broke my nose i guess the universe really does have a way of evening itself out. Moral of the story: I got a d44 and 14bff with 4.56's
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 and some K5's lol |
