![]() Join Date: Nov 2008
Parting out Complete 1972 Long Bed
I am selling parts or pieces off the truck pictured. The body is mostly rough and or rusted, but would have some patches if you need? Engine appears to be complete as does the drivetrain. Ask if you need anything not priced.
Black door panels $85 shipped gove box door $25 shipped ashtray $15 shipped gauge cluster $45 shipped steering column -3 spd $65 shipped horn button $20 shipped one good visor $20 shipped 350 engine complete $250 3 speed transmission $50 Hurst Indy shifter/linkage $75 shipped complete frame w/rear and front discs $250 Ask about anything else. ![]() ![]() ![]() ![]() |
Re: Parting out Complete 1972 Long Bed
![]() Join Date: Apr 2007
Heat riser tube and manifold shield and manual throttle assembly with gas pedal? Received payment and shipped your horn cap today. Tried to send PM but your inbox was full. Thanks, Sharpie
Sharpie, I just got that inbox cleaned out, so sorry for not being able to accept earlier. How does $35 shipped sound for the parts you need??
Sounds great. Shoot me a PM on payment details. Thanks, Sharpie
![]() Join Date: May 2002
what gears are in the rear end? Posi?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 07-19-2010 at 06:34 PM. |
Not sure of rear end gears or how you tell?? Not marked on glove box as having a posi rear.
![]() Join Date: Sep 2007
how are them dog dishes looking, can you take a pic of one or 2 of them? I see 3 you have all four?
1967custom |
I have all four hubcaps. Three I would call veyr nice and the fourth has some dents. I will post some pics for you in a bit.
the easiest way would be to open the differential. however, you can also jack up the rear of the truck, mark the driveshaft and tires, then rotate the driveshaft. however many turns it makes compared to 1 revolution of the tires is the gear ratio. also with it jacked up, if the tires rotate in the same direction, it should be a posi, however, if they rotate in opposite directions, it's a one tire fryer.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
michael bustamante,
Here are the caps. Two are pretty decent and one fair, and one bad. $25 for all shipped. ![]() ![]() |
#13 |
Restoration Virgin!
is that wood grain bottom trim??.....what condition is it in?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#14 |
It is woodgrain bottom trim. Condition varies from some being acceptable and good driver condition to some being bad and or dry wall screwed on. If you need any specific pieces let me know.
#15 |
Restoration Virgin!
I'd be interested in anything that's good from the back of the cab to the front clip (not interested in the bed stuff)....if it's not too much trouble, maybe pictures of the good stuff before you remove it???
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 07-20-2010 at 10:48 AM. |
#16 |
Does it have a front sway bar? If so, what size. Thanks
#17 |
that last one is pretty bad. I dont think its fixable, can you do 20 shipped? If so Ill take em
1967custom |
#18 |
#19 |
you got it, what s the payment info?
1967custom |
#20 |
#21 |
#22 |
Thanks but I will pass on sway bar.
#23 |
Chevy Lover Till The End.
What kind of shape is the tailgate in?
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#24 |
#25 |
Not sure if that pass. ram horn exhaust manifold will fit the 283 but if so how much shipped to 75040?
Also how much for the radio complete with knobs and all?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
