07-19-2010, 06:06 PM | #1 |
Big Block question
Can I run a full roller valve train under stock valve covers? And if not who makes stock looking covers that will? I want the engine bay to look as stock and clean as possible so it looks like it came from the factory like that.
John Bernard Books (The Shootist): "I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them." |
07-19-2010, 07:29 PM | #2 |
Re: Big Block question
Here are a couple, kind of Ferrariesque!
07-19-2010, 08:37 PM | #3 |
yeller
You will need tall VC'ers to run most roller rockers. However, I am pretty sure there are aftermarket spacers out there that will help you achieve the look you are after and allow you to run a modified valvetrain.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-19-2010, 10:32 PM | #4 |
cool thanks guys
07-20-2010, 12:36 AM | #5 |
07-20-2010, 07:50 AM | #6 |
Comp Cams or Crower steel rockers will fit under a stock valve cover with no need for extra gaskets, that's what most of the big block guys use when they're going for a stock look. It's the bulky aluminum pieces that cause problems.
