07-19-2010, 07:46 PM | #1 |
Rear 2" drop question
I would like to level the stance out on my 72 C10 until I have the funding to do a full 3/5 or 4/6 with rims next year.
If I buy a set of 2" drop springs plus new retainers and bolts will that be all i need to level this stance out from stock ride height? |
07-19-2010, 07:57 PM | #2 |
Tot Roddin'
Re: Rear 2" drop question
A cheaper way to do this would be to use a block in the rear. If you know someone that can cut out the blocks, and drill the, it's a piece of cake from there; probably less than $100.
You can run 1" and if that's not enough up it another inch to a 2".
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 07-19-2010 at 07:57 PM. |
07-19-2010, 08:00 PM | #3 |
dazed and confused
i agree with 72blackbeauty
members met: redbaron69, billsbowtie,nc67 |
07-19-2010, 09:53 PM | #4 |
Grandpa in the rustmobile...
Id get a block first. I duno where everyone gets the U bolts at though
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-19-2010, 10:50 PM | #5 |
2X2 tuben thick wall, cut 7" long drill 2 5/8 holes go to AutoZone and get the Ubolts for 19.99 and there you go.
Cut 1 complete round out of the bottom of the front springs! How cheap can it get..............
Things happen for a reason! |
07-19-2010, 10:54 PM | #6 |
One day.....
I got my set for around $40. Machine shop 2 inch square tubing $20, and as for the the u bolts, I went to a local spring shop. They custom made/bent them while i waited, $22. With nuts and washers.
DZL1. |
07-20-2010, 10:34 AM | #7 |
Guys, thanks for the feedback (and the curve ball lol). Now i need to figure out this block method if i decide to go that route.
I thought it be as easy as buying $85 in springs and plug and play. |
07-20-2010, 03:03 PM | #8 |
Tot Roddin'
It can be that easy but there's a cheaper way (blocks) to get the same drop and not end up buying double the springs to bring your truck down. Plus... you can still use your blocks depending on how low you want to go with your new drop springs (future purchase).
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-20-2010, 04:29 PM | #9 |
Find a place that does lifts and see if they have any jeep springs or look on CL for some. Probably find some for cheap or maybe even free. They will give you a 4 inch drop in the back. Then pull the front springs and cut a single coil out like BIG ORANGE said. That would (could) put you at about a 2/2.5-4 for virtually nothing but your time.
'67 C-10 Shorty - 454, 5spd, and speed holes! |
07-20-2010, 09:07 PM | #10 |
Im runnin jeep springs but am on the verge of needing adj. tracbar (almost perfect but still a lil off) I need to
A Make one B buy one C put stock springs back in I plan on cutting front springs too, will i need to get it realigned? (that much difference or what)
07-20-2010, 09:50 PM | #11 |
Moderator
Jeep Wrangler springs gave me maybe 1/4" drop in the rear....nowhere near the 4" I see claims of on here. Before anyone asks, yes they were from a 2002 Wrangler TJ. They are much thinner gauge than the stock coils, but they did not drop the rear, even with two people standing in the bed. I have 2" block in my other truck and it sits lower than my truck w/ the Jeep springs. Cutting a single coil in your front springs WILL drop the front about 2", that worked perfectly for me.
07-20-2010, 10:06 PM | #12 |
OK,at the risk of sounding like a complete idiot,can someone show me what you mean about the block lowering deal ?
07-20-2010, 10:11 PM | #13 |
block would go between axle and trailing arm
My TJ springs gave me, i dunno right off hand but at least 3-4" thats the best pics ive got all stock just TJ springs, I know my shocks need to be lowered shocks an adj tracbar, and shock relocators...
07-20-2010, 10:15 PM | #14 |
Moderator
Wow...they did lower your truck, mine looks NOTHING like that, in fact it still looks the same, just like your first picture. I do have a SWB but I did not think the lower weight would make that much of a difference.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-20-2010, 10:15 PM | #15 |
One day.....
07-20-2010, 10:28 PM | #16 |
Thanks for the link,had to walk outside and look at my 69,just didn't quite get it,but now i understand.
07-20-2010, 10:28 PM | #17 |
Are they new springs ledzepp? Mine are used, but not heated or anything, is the bed on?
Only thing I dont like about em is I use my truck as a truck but like the lowered look..I cant haul anything with these, may do a simple bag on the rear oneday..
07-20-2010, 10:35 PM | #18 |
Moderator
Used, 03 Wrangler, bed is on (even had two people standing in it). I can get it about 6" lower if I bounce the bed up and down But sitting stationary, no drop.
07-20-2010, 10:45 PM | #19 |
huh..
maybe drive ti some and they'll settle, sure ya didnt put nothin on backwards..
07-20-2010, 10:53 PM | #20 |
Moderator
LOL, they won't settle 4". As soon as I get the chance, they are going in the trash and I am off to CPP to get real ones made for the truck.
07-20-2010, 11:01 PM | #21 |
lol see if someone on here wants em first..lol
07-21-2010, 10:45 AM | #22 |
Thanks for everyone's feedback. Let me ask this another way.
Assuming to have $150 budgeted for this 2" rear drop project. Would everyone still be in favor of the block as opposed to just buying and installing the 2" drop springs? My ignorance level is high hence why i am asking. It seems the block method is a slightly cheaper way of doing what the spring swap will do. Or, is there more to is that than? ride quality, safety, ect thanks guys! Jeff |
07-21-2010, 01:05 PM | #23 |
Kill Bill...et
I'd go with the blocks. Plus, it'll keep the origional geometry in the rear. You can't go wrong.
07-21-2010, 04:35 PM | #24 |
Yes block first
07-21-2010, 05:04 PM | #25 |
what is the benefit of blocks versus 2" drop springs? (not concerned about cost)
and to a new 67-72 owner with limited knowledge of all the mechanic of them, the block process is detached the u bolts from the trailing arm/axle and installing the blocked and new u bolts??? the 2" drop springs would involve removing the old and replacing wiht the new? sorry for all the questions, just not quite following it all yet. thanks!! |
