Old 07-19-2010, 11:01 PM   #1
Hubscrub
Cruzin
Hubscrub's Avatar
Fan Shroud?
i have a 71 chevy and i am going to put a shroud and 7 blade clutch fan on it to get rid of the flex fan will a standard shroud work since my engine is in the back position like a inline would be, or do i need a 4x4 shroud i have been told the 4x4 shroud is deeper thanks
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-20-2010, 12:06 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Fan Shroud?
you would be better off putting a 1" or longer extension (over what you have now) getting the fan closer to the radiator...then a standard shroud would fit and the fan would pull more air thru the radiator.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-20-2010, 10:54 AM   #3
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: Fan Shroud?
+1. Get a clutch with a long extension neck too. You can look at the Hayden catalog (online) and find a clutch, maybe for another vehicle, with the same bolt and pilot hole dimensions (which are the same on many old domestic vehicles), but with a longer neck. The catalog lists all of the dimensions, which is cool.
Most stores like Advance Auto can lookup those part numbers directly. The temperature parameters are the same, so you don't have to worry about that. I've done this before on custom engine jobs.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 07-20-2010, 12:16 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Fan Shroud?
fwiw, my 4x4 shroud measures 9" from the front lip to the fan opening. The fan is right where it should be. I measure 6" from the radiator to the fan clutch -- and about 9 1/2" from the radiator to the mounting surface on the water pump pulley.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-20-2010, 02:23 PM   #5
68GMCCustom
Re: Fan Shroud?
yes...some vehicle designs required the fan to be further back from the radiator...and they have special "deep" shrouds to accomodate. Its not the prefered scenario tho... as the closer the fan is to the radiator...the more efficient it is at moving (pulling/pushing) air through the radiator.
Kurt -
Old 07-20-2010, 02:48 PM   #6
storm9c1
storm9c1's Avatar
Re: Fan Shroud?
Not only that, but a thermal fan clutch needs to be close to the radiator so that it can receive the right temperature (for proper lockup). IMO, once you move the clutch over 1" away, you may have overheating problems. Try to keep the fan as close to the radiator as possible by using a fan clutch with a longer shaft or use a spacer behind it.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 07-20-2010, 05:58 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Fan Shroud?
thanks all for the help i will do some looking and see what i can find
Proverbs 3:5,6
Old 07-20-2010, 08:58 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Fan Shroud?
I don't think it matters much (within reason) if the shroud is correctly designed.... the fan will pull all possible air through the radiator.
Maybe.... but as I posted above, my clutch fan is 6" from the radiator (factory design) and has the oem shroud. In 33 years (that I know of) it has not had an overheating problem. Well, it did once, when I temporarily installed a flex fan...
- Mike -
RIP El Jay
Old 07-20-2010, 11:02 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fan Shroud?
hey hub, ATT had a shroud awhile back I think he said he had one at least, may check his craiglist stuff out..
John
1999 Toyota Tacoma 4x4
Old 07-22-2010, 09:19 PM   #10
mexgrhd68
mexgrhd68's Avatar
Re: Fan Shroud?
eh, u dont need it, ive been running mine in that position for around 15 years..305/350 combo.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 07-22-2010, 09:30 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
Re: Fan Shroud?
I thought I had a bright idea by mounting an 80's clutch fan in place of the stocker on my Army truck budget build. Only problem is, the clutch fan is a larger diameter and won't fit in the shroud...
WIDESIDE72 is offline   Reply With Quote
Old 07-22-2010, 09:51 PM   #12
oldblue1968chevy
Re: Fan Shroud?
yeah..lol my late 70's motor's fan wouldnt fit in the 67-72 shroud..lol good thing i had a parts truck
John
Old 07-22-2010, 10:02 PM   #13
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Fan Shroud?
how much did it like from fitting alot?
Proverbs 3:5,6
Old 07-23-2010, 01:23 AM   #14
bjinx
bjinx's Avatar
Re: Fan Shroud?
I am using a stock shroud on my '70 with a Flow Cooler short pump and an AC Delco fan clutch I got from ROCKAUTO. The engine used to run about 200* in the summer, the delco fan clutch brought it down to 185-190,made all the difference in the world. They are alot cheaper at Rockauto.com
bjinx is offline   Reply With Quote
Old 07-23-2010, 11:11 AM   #15
oldblue1968chevy
Re: Fan Shroud?
it was DANG close hub, but it just didnt fit
I got the fan from my 72 350ci parts truck worked good!
John
