Old 07-20-2010, 02:02 AM   #1
bigwheel15
bigwheel15's Avatar
How to remove leafs?
Well I have been reading on the boards about dropping my rear more. Right now I have a flip and soon ill be adding a notch and possibly some shackles. But what I was wondering is how do you remove a leaf from the rear? Whats the process? I see a lot of talk about it but havent been able to find anything about how to go about it.
bigwheel15 is offline   Reply With Quote
Old 07-20-2010, 08:38 AM   #2
primetime
primetime's Avatar
Re: How to remove leafs?
i replaced my leaf springs on my 77 about a month ago. the first thing my wife and i did was pre-soak all the bolts/nuts with wd-40. the leaf spring mounts on the hanger and mounts on the shackle. soak both of those like 2 days before you start. i jacked my truck up on jack stands. with the frame supported on the stands, i use the jack to support the weight of the diff. that way i could raise or lower it to get the tension off the bolts. after i did those two main bolts i focused on the u-bolts that hold the diff on the leafs. have those soaked down in advance too. although most people say to cut the bracket, i found it just as easy to unbolt it. good luck. taking it out was the easy part for us. installing the new one was a royal PITA.
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 07-20-2010, 09:43 AM   #3
justpball
justpball's Avatar
no primetime, he is talking about removing a few out of the pack to lower it some more.
you need to jack the truck up and put jack stands under the frame, then put some jack stands under the axle tubes and take the u-bolts loose, I would put new u-bolts if it were me, jack up the rear a little to take the weight off the leafs, and raise the jack stands to hold it. now there is a pin running through the spring pack that has a round head and is the location pin for the rear that sets in the saddle block. clamp off the spring pack with two large c-clamp on each side of the pin as far out as you can and still clamp off all the springs. now take out the pin bolt and SLOWLY let the pressure off the clamps until the pressure is off the springs, remove the ones you want to take out then put it all back together with the clamps and put the pin back in...sometimes the bolt breaks and all you do is get a new bolt that is the same size and then round the head with a grinder or file, once you put it back in the pack. then put it all back together.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 07-20-2010, 11:06 AM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Like this:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-20-2010, 02:29 PM   #5
justpball
justpball's Avatar
^ just like that^ ...LOL thanks for the pics to make a little since of what I said...LOL
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-20-2010, 03:16 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I usually just sweep them out the back of the bed with a soft broom! JustKidding of course
--Josh
Old 07-20-2010, 07:39 PM   #7
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
if you already have a flip kit all you need is some lowering blocks, i removed leafs from my truck and i'm not 100% happy on how it hooks up when i get on the throttle.
staggerd86c-10 is offline   Reply With Quote
Old 07-20-2010, 11:18 PM   #8
lilshaunsdad
lilshaunsdad is offline   Reply With Quote
Old 07-21-2010, 10:25 AM   #9
justpball
justpball's Avatar
true, you could just do blocks...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-25-2010, 01:57 AM   #10
iroc12valve
please use C Clamps as they thread as oposed to just clamping just my .02 but i was concerned by the extenda clamps
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
