Old 07-20-2010, 10:19 AM   #1
DREW67
DREW67's Avatar
Repro Short bedsides
Has anyone used the new repro short bedsides? And how did they fit?
DREW67
DREW67 is offline   Reply With Quote
Old 07-20-2010, 02:26 PM   #2
SBC
SBC's Avatar
Re: Repro Short bedsides
i think a lot of people have used them, there are several old post about them. i recently put mine together and didn't run into any issues.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 07-20-2010, 02:54 PM   #3
DREW67
DREW67's Avatar
Looks good. How does the tailgate line up?
Thanks for you help?
DREW67
Old 07-20-2010, 09:13 PM   #4
Joesjunk
Joesjunk's Avatar
Andrew, Rick just built a complete new bed, floor and sides. There are some issues, but not too bad.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-20-2010, 10:00 PM   #5
DREW67
DREW67's Avatar
Thanks Joe I'm going to have to talk to Rick one day to see what issues he had.
DREW67
Old 07-21-2010, 12:23 AM   #6
HOTFUN
HOTFUN's Avatar
Hi Andrew. We just put together a fleetside short box in our shop mating two Goodmark bedsides and front bed panel to an original GM steel floor and GM tailgate. The sides are really straight across the bed rails front to back and down the bed sides and only two small issues so far as the box is not installed on the truck to check the front alignment to the cab for width and lines. One issue was the box side lip on the front edge had to be trimmed where it met the front bed panel and ground a little. Really not hard retrofit but it was noticeably not right. The harder issue was the drivers side rear of the panel was not stamped and spot welded quite deep enough for the tail gate to lay flush with the taillamp panel when closed. A little body finness and slotting of the hinge holes and it appears probably as close if not better than original. I always finish out the spot welds anyway but these new ones are a little more pronounced than the originals too. The RH tail lamp panel fit fine to the tail gate when closed so maybe I got a mis stamped drivers panel too. I would definitely always do a dry fit of all your lamps and the tailgate before doing any final finish and paint work. We did some fitting and trinming to align them in the holes. Overall the whole reproduction bedsides are better than reworking rusty panels with patch panels and finding hidden bondo. I'm going to build one more with some original used boxsides I have saved and from then on no regrets building the rest of my projects with repo bedsides. The price of NOS and what condition they are and also the used originals are in anymore makes these reproduction panels a very reasonable alternative. My opinion is with a little patience and experience you can make these panels look as good if not even better than GM built them back in the day. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
Last edited by HOTFUN; 07-21-2010 at 12:38 AM. Reason: making a better way to SEE the USA!
HOTFUN is offline   Reply With Quote
Old 07-21-2010, 12:42 AM   #7
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by HOTFUN View Post
Hi Drew, We just put together a fleetside short box in our shop mating two Goodmark bedsides and front bed panel to an original GM steel floor and GM tailgate. The sides are really straight across the bed rails front to back and down the bed sides and only two small issues so far as the box is not installed on the truck to check the front alignment to the cab for width and lines. One issue was the box side lip on the front edge had to be trimmed where it met the front bed panel and ground a little. Really not hard retrofit but it was noticeably not right. The harder issue was the drivers side rear of the panel was not stamped and spot welded quite deep enough for the tail gate to lay flush with the taillamp panel when closed. A little body finness and slotting of the hinge holes and it appears probably as close if not better than original. I always finish out the spot welds anyway but these new ones are a little more pronounced than the originals too. The RH tail lamp panel fit fine to the tail gate when closed so maybe I got a mis stamped drivers panel too. I would definitely always do a dry fit of all your lamps and the tailgate before doing any final finish and paint work. We did some fitting and trinming to align them in the holes. Overall the whole reproduction bedsides are better than reworking rusty panels with patch panels and finding hidden bondo. I'm going to build one more with some original used boxsides I have saved and from then on no regrets building the rest of my projects with repo bedsides. The price of NOS and what condition they are and also the used originals are in anymore makes these reproduction panels a very reasonable alternative. My opinion is with a little patience and experience you can make these panels look as good if not even better than GM built them back in the day. Mark
You said you used Goodmark bedsides. I have always heard they make good quality parts. I would think, just like all aftermarket parts you will get what you pay for. At least as a rule. I have only used aftermarket body panels a handful of times but I have always had to do a little work on something to make them fit "right". Like Mark said it's much better than dealing with the shoddy body work and rust you run into on many of our trucks.
mcbassin is offline   Reply With Quote
Old 07-21-2010, 08:31 AM   #8
DREW67
DREW67's Avatar
Thanks Mark.
DREW67
Old 07-21-2010, 05:04 PM   #9
vincentgkirkland
vincentgkirkland's Avatar
just make sure its tri plus brand. real stuff
vincentgkirkland is offline   Reply With Quote
Old 07-21-2010, 09:06 PM   #10
project67-stepside
project67-stepside's Avatar
dont get the grumpys ones there certifit
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
