Old 07-20-2010, 04:04 PM   #1
Mikewb
crossmember problem
i have an 82 swb half ton two wheel drive. used to be a standard 4 speed. I switched it to a turbo 350 and after the trans mount is too far forward to bolt up to the crossmember. Any easy way to make it work?
Mikewb is offline   Reply With Quote
Old 07-20-2010, 04:29 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: crossmember problem
Unbolt the crossmember and slide it to where the trans mount will mount up to it, then bolt it back up to the frame. Chances are the holes will already be there. If not, grab a drill.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-20-2010, 04:39 PM   #3
Mikewb
yea theres only one set of holes guess ill need to make new ones
