Old 07-20-2010, 04:26 PM   #1
ybnaford
Junior Member
ybnaford's Avatar
01-06 Chevy Front Wheel Bearing Assemblies
It started last year right before my Nov 09 hunting trip to NE. During daily driving I would hear a very faint noise that sounded like a brake pad indicator rub but it was only when turning slightly. When I got around to rotating the tires for the trip, I found the Left Front Wheel Bearing Assembly was bad on my 04' 1500 Silverado Extcab 4x4 with 84.5K miles. Told my buddy who has an 06' 2500 HD Crewcab to check his. His mileage 84K, LFWB assembly was bad also. Called my dad in NM who has a 06' 2500 HD crewcab with 88K miles. His LFWB assembly was bad as well. Called my father in law in NE with 4 Silverados on the family farm ranging from 01 to 03 and compared notes on LFWB and RFWB assemblies. They also had to replace both units between 80K and 100K. At the end on Jun 2010, my buddy with the 06' 2500 HD Crewcab, called me and told me he finally had to replace his RFWB assembly at 89K miles. So it seems that between 80K and 100K the Front Wheel Bearing assemblies need to be checked on 01' -06' Silveardo's that are 1500 and 2500 4x4's. This is just what I and my family and friends have experienced with these trucks and hopefully it will help. The assembly prices range from $159 to $230. The unit warranties seemed to be anywhere from 1yr, 2yr & lifetime warranty. My buddy used Temken assemblies which were at the upper end of cost.I used the PEPBOYS 2yr warranty unit. It had the rounded tip studs (similar to stock) and not the squared off tip studs which was the 1yr warranty one. The PEP cost was around $199. NAPA's price was around $159 but I believe that was a 1yr warranty. Change out time was between 1.75 and 2.5 hours per assembly. It does save you some money if you can do it yourself. Just takes a little sweat to do it.
ybnaford is offline   Reply With Quote
Old 07-22-2010, 03:47 PM   #2
JohnC
JohnC's Avatar
Re: 01-06 Chevy Front Wheel Bearing Assemblies
Yep we've replaced them on my 03 1500HD, and on our 02 2500HD. Also seem to have replaced them on a regular basis on my daughters 00 Grand Prix. They just don't make as much stuff to service like they used to. You just have to replace stuff now.
JohnC is offline   Reply With Quote
Old 07-24-2010, 09:18 AM   #3
dmarty
Active Member
dmarty's Avatar
Just replaced em on my '99 1500 4x4 Silverado at 270K miles. No complaints here.
72 GMC Sierra Grande SWB 402 BB A/C
(Owned it since 1973)
99 Silverado 1500 LT with 315K miles
(RIP)
2012 GMC Sierra SLT
dmarty is offline   Reply With Quote
Old 07-25-2010, 06:33 PM   #4
Black 95 TSI
I had 170k on mine before I traded the truck in, and never had to replace the WBs. I have seen some GM cars and trucks with as little as 30k and needed WBs.
70 C10 SWB stepside forsale
00 Silverado Z71 Sold
95 Eagle Talon TSI turbo (Hellz ya its fast)
70 Chevelle
69 firebird
10 Silverado 4x4
Black 95 TSI is offline   Reply With Quote
Old 07-27-2010, 01:26 PM   #5
smbrouss70
smbrouss70's Avatar
Is this just 4x4's or is it on 2wd's also?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-27-2010, 11:28 PM   #6
Black 95 TSI
I have done just as many 2wd as 4wds.
70 Chevelle
69 firebird
10 Silverado 4x4
Old 08-10-2010, 12:03 PM   #7
fxdxharley
Just a nother gear head
fxdxharley's Avatar
did my 2000 2500 4wd at around 110k just the right side so far. left is orig and its got 160k on it now.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 08-14-2010, 12:37 AM   #8
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
my 00 2wd has a 130K and i think it needs both.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-14-2010, 02:51 AM   #9
Justin87
Justin87's Avatar
My 00' Sierra has 154k and needs the front left replaced. Not sure if it's the original since I just bought it back in January.
2006 Silverado 2500 HD
Justin87 is offline   Reply With Quote
Old 08-14-2010, 10:02 AM   #10
smbrouss70
smbrouss70's Avatar
My 04 2wd has 110k so I checked and they both seem good for now. I'll keep an eye on them though.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 08-14-2010, 10:35 PM   #11
structures
structures's Avatar
I have a 03 Z71 and it needed front brake pads in January this year. So I thought I'd do a quick rotor/pad job it was probably 30 deg outside. Well ended up doing the drivers side in about 25 minutes went over to the passenger side and noticed not only was the wheel bearing shot but my seal on the front differential was throwing fluid. So my quick little brake job ended up costing me a lot. Had to pull the half shaft and the RH housing for the differential. I was thinking that the worn hub bearing caused the seal to go bad. Or caused the seal to leak fluid.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 08-16-2010, 01:44 AM   #12
presleyhome
I had to do the front right on 2001 HD2500 4x4 at about 80,000.
Jim P
1981 Sierra C2500 LB Fleetside, 350M, Th400, QJ, 14bolt 10.5" rear.
presleyhome is offline   Reply With Quote
Old 08-17-2010, 07:34 PM   #13
Burb
Coordinator of Synchronicity
Burb's Avatar
Did both on my 2001 @ 182 k myself
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 08-17-2010, 09:50 PM   #14
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
thanks for the heads up, I'll check my tahoe since it has 132k on it.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
